Customs 51 Merc -- Body OFF -- Custom Chassis
Discussion in 'The Hokey Ass Message Board' started by enfieldjoe, Aug 13, 2011.
  1. EXK
    EXK
    from SO CAL
    Hey Joe, It's realy looking good. Your ride height is going to scare the hell out of the local small rodant's. Oh my vote is for the 54 merc bumper
  2. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Rick: The pix in Post #30 is with zero pressure in the air suspension. Layin Frame in those pix. That height should scare even the ants....
  3. 1beatnik
    1beatnik
    from indiana
    Looks perfect in your avatar. wow
  4. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Thanks, yeah, I am kinda diggin the look without the fender skirts.
  5. ELpolacko
    ELpolacko
    That's pretty inspirational.
    We finally got the floor and rockers back together on the fordoor I have been working on. Now it's back on the stock ch***is and we can determine ride heights. I'm sure if my customer sees this, he may want to ditch the idea of traditional suspension mods... :)
  6. leadsledmerc49
    leadsledmerc49
    Lookin' REAL nice Joe!!!
  7. outlaw1949
    outlaw1949
    Is that a fatman mustang II stub???
  8. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    That looks killer man, glad you put it on that frame. The rear of the roof is dechrowned for laying that low, wouldn't make as much sense if it wasn't laid down like that, but I think that's pretty sleek.
  9. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Yes, SlddnMatt installed a FatMan Fab front clip on a stock 51 Merc ch***is. Matt also added bags & shocks on all four corners. Rear is a Ford 9inch with triangulated four link.
  10. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Yeah, Chris you get all the credit for an absolutely KILLER chop!! You got the calibrated eyeball IMHO. Well Done!
  11. EnragedHawk
    EnragedHawk
    from Waco, TX
    Looking sick! I'll be keeping tabs for sure!
  12. outlaw1949
    outlaw1949
    Thx, it lays low, thats what I want mine to do:)
  13. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Making some progress, but it is slow going because I got my 50 Merc back and now I am sharing time between both projects.
    I removed the spare tire well (bunch of patches and did not plan to put a spare tire in there anyway). Finished up welding the sheet metal that replaced the spare tire today. Spend some time on grinding the welds and it will be finsihed.
  14. Car looks sweet! What does a '51 look like with a '54 rear bumper?
  15. enfieldjoe
    enfieldjoe
    from Eustis, FL
    A 54 Merc rear bumper is supposed to look really nice on a 51. Slddnmatt is doing a 54 for a guy building a 51 over here in Charleston, SC. That is my plan, but have to score a 54 bumper first.
  16. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Did more work on the complex shape that is required for the under-the-rear-seat-floor-pan area because of the air suspension and 9-inch rear and four link suspension. Designed and fab'd some features in the floor so that the upper L&R four links have room to articulate without contacting the floor. Have to do the same for the driveshaft. Lots of sheet metal fab in this area to include fabricating a cover for the 9-inch rear.
  17. billys54
    billys54
    Looks good so far
  18. Leadsled612
    Leadsled612
  19. EXK
    EXK
    from SO CAL
    Wow Joe it looks like you have your work cut out for you (no pun intended) but it looks like you have it handeld. Keep up the good work. I do have a question about your lower rear bag mounts as in your pic's i can not tell if they are attached to the axle or the trailing arm.
    Rick Erickson
  20. desotot
    desotot
    looks very good, twill be a sweet ride.
  21. slddnmatt
    slddnmatt
    havent took any pics of the bumper after i finished it out, they fit ok without too much work, they are a little flatter across compared to a 51. you also have to mess with the ends a little or they will hit the body. if you want it to fit like a glove there is a fair amount of work to get them to fit tight. if i get a chance, ill take a pic or two tomorrow. Rick the lower bag mounts were attached to the axle.
  22. Sweet build, keep the faith.
  23. thisbugger
    thisbugger
    Looking good!!!
  24. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Been working the Merc alittle at a time. Struggling with the sheet metal fab because I don't have a brake. Have to make a trip to a friend's shop to make the bends, which really slows down the progress.
    Had to remove alittle more trunk pan that originally planned because their was interference with the trunk pan and the rear suspension crossmember (used to be the upper attach point for the stock rear shocks). So, these pix show the removed section and then the new pieces installed in place. Still struggling with my new Miller 211 MIG, but getting there one tack weld at a time.
  25. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Now I have all the major sheet metal pieces to cover the rear suspension fabricated and fitted. Only some final welding/grinding and fasteners left to complete this task. Planned to use Dzus fasteners to remove the panel over the rear suspension just in case I wanted to repair, or mod rear suspension components. The end result looks simple, but it took some planning to get it right.
  26. enfieldjoe
    enfieldjoe
    from Eustis, FL
    In the process of fixing rust in the driver's side front floor pan.
  27. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Just about finished replacing the driver's side rear floor pan. It was pretty beat after I media blasted the bottom of the body. It was very evident that it needed to be replaced.
  28. richie rebel
    richie rebel
    looking good my man
  29. looks bad*** man! i would love to see more pics of the rear suspension! i like the uppers, how he shaped them to help clear the seat maybe?
  30. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Onto the modified driveshaft tunnel installation. Doing some mockup to identify the cut-lines.
