Technical 51 Merc, coil smoking???
Discussion in 'The Hokey Ass Message Board' started by mr57, Aug 16, 2015.
  1. I installed a 55 Ford regulator in my 51. Using a 12 volt battery and it turned over real easy. I ran the battery down and when I had it charging, the coil started to boil and smoke. I did forget to polarize the regulator when I swapped out the battery. Would this have done it? Or should I have switched over to a 12 volt coil?
  2. BJR
    BJR
    Should have switched to a 12 volt coil. A 55 Ford regulator is 6 volt. You can't mix all that stuff and expect it to work. Either stay all 6 volt or switch everything to 12 volt. For the switch to 12 volt you need; 12 volt battery, generator or alternator, if generator you need a 12 volt regulator, 12 volt coil, 12 volt bulbs, voltage drop for the gages, heater fan, and radio. The stater and horn will work on 12 volt.
  3. Slopok
    Slopok
    If you're using a 12 volt battery you'll need a 12 volt regulator, generator or alternator & a 12 volt coil.
  4. Was told by someone on here that a 55 Ford had 8 volt regulator as it was a transition year and the 12 volt battery would work as long as the regulator was changed.......So much for that advice....Hope I didn't toss the old regulator.....
