Technical 51 merc overdrive question
Discussion in 'Traditional Hot Rods' started by nailheadjay, Mar 13, 2014.
  1. Mike51Merc
    Mike51Merc
    Another interesting thing is that you can install a "manual override" switch to override the automatic features. Best of both worlds, I guess.
    As for the upshift while freewheeling--- perhaps an experiment is in order.
    To 38Coupe's point: Yes, the engine speed has to drop, but if you are freewheeling I'll ***ume the engine is idling and you haven't lost your brakes. I've got a nice 5 mile downhill run to try this on.
  2. tommy
    tommy
    The first time I drove my 57 to work I forgot about the freeweeling. I stopped at the grocery store on the way home. When I got out, the car started to roll away!! I was able to slow it down and get back inside before it hit anything.
  3. Mike51Merc
    Mike51Merc
    Put shifter in R to stop freewheeling when parked.
  4. TheMerc
    TheMerc
    Depends on the transmission, mine has a reverse lockout when overdrive is engaged. (freewheel) That is why my emergency brake works so well.
  5. rotorwrench
    rotorwrench
    I was raised up in western Kansas so most overdrive operation in our old 51 Merc was on the flats. We did occasionally travel up to Denver Co. When we got into the hills, the lock out handle was pulled out so that we could use the engine as a brake going down hill and no overdrive for climbing. Leaving the overdrive system engaged in mountain country can get you in a world of hurt. It's also hard on the brakes.
  6. nailheadjay
    nailheadjay
    great info!!! thanx hambers!!
  7. skidmarc
    skidmarc
  8. Cosmo49
    Cosmo49
    Sorry for the late post, these two pictures are the individual components of the governor on my '69 model. As above my friend machined a new piece from a small piece of Micarta.
