51 Merc overdrive
Discussion in 'The Hokey Ass Message Board' started by JJAGS3, Jan 26, 2011.
  1. JJAGS3
    JJAGS3
    Hi. How much of the 6 volt overdrive system do I have to replace now that my car is 12 volt? One guy said the solenoid only but I'd like to make sure before I hook it up and fry of the the 6 volt parts.
  2. Mike51Merc
    Mike51Merc
    You're gonna get different opinions. My friends 51 Ford is running 12V with all the original 6 volt OD components for years with no problems.
  3. SportSedan
    SportSedan
    Allso My 49 Merc has run years with no problems.
  4. oldcarfart
    oldcarfart
    just run it, go to studebaker drivers club website for circuit upgrades but the parts on the tranny will last forever.
  5. Fortyfordguy
    Fortyfordguy
    We've always figured on the solenoid and the relay being the voltage sensitive components. Both are different for 6 or 12 V systems. I'll have to find out why on the relay. The governor and the kickdown switch don't care which voltage. Wiring of proper gauge and GOOD grounds are imperative.
  6. oldcarfart
    oldcarfart
    The relay can be rewired to use a "Hella" style headlight relay in the stock firewall mounted box or you can use a toggle switch for manual override.
