`51 merc rear end swap
Discussion in 'The Hokey Ass Message Board' started by banditomerc, Mar 22, 2006.
  1. banditomerc
    banditomerc
    whats the easiest and cheapest rear to install ,and yet retain the bolt pattern.I heard the mid `70's granada was a good candidate.thanks
  2. Deuce Roadster
    Deuce Roadster
    The 1951 Mercury has the 5 on 5.5 wheel pattern ..from the factory....and the Granada is 5 on 4.5 :) NOT the same wheel pattern....
    :D
  3. 51 MERC-CT
    51 MERC-CT
    F-100 pickup truck:) :D
  4. solo_909
    solo_909
    i picked up a 71 f100 and its the same. the only thing is you have to cut off and reweld the shock mounts and leaf pads but other thasn that its a perfect fit = )
  5. fatty mcguire
    fatty mcguire
    too bad you werent closer because i was told my ford 9 is bolt for in your car
  6. banditomerc
    banditomerc
    thanks for the info!!!
  7. punkrex
    punkrex
    from PacNW
    an explorer 8.8, 96+ come equiped with factory disks
  8. 55 dude
    55 dude
    f-100's 57-72 are same width and they make millions of them!
  9. solo_909
    solo_909
    Yo Banditomerc heres a 51 rear and a 71 rear lined up. you can see its a perfect match.
    And here are the parts that will need to be cut off and welded on the opposite side. the leaf spring pad needs to come out about 3-4 inches too ( you can see the difference in the first pic
