51 Mercury Leaking differential
Discussion in 'The Hokey Ass Message Board' started by JJAGS3, Jan 27, 2014.
  1. JJAGS3
    JJAGS3
    The differential in my 51 Mercury is leaking through the seal where the driveshaft attaches. Do I have to remove the differential to replace this seal or can I do it with it still on the car. Thanks
  2. ebfabman
    ebfabman
    Remove drive shaft, remove pinion yoke, remove old seal, clean everything up, install new pinion seal and put all back together. pizzacake.
  3. You can do it without pulling the center section, just remove the pinion nut and yoke, replace the seal, and reinstall the yoke/nut. DO NOT overtighten the nut, and put some locktite on the threads.
    The OEM seals in these were leather, and if the replacement is leather pre-soak it in some motor oil until it's soft before installing it.
  4. JJAGS3
    JJAGS3
    Thanks. Sounds like something this old 3/4 of a century old guy can do.
  5. Mike51Merc
    Mike51Merc
    Before you remove the pinion nut, mark both the nut and the housing so you can reinstall the nut in the exact same position.
  6. flathead4d
    flathead4d
    Good advice from Mike51Merc. I was going to suggest the same thing. If you don't mark the position of the nut when you put it back on, the lash between the ring gear and pinion gear will change. That will make your rearend noisy and you don't want that.
