Projects '51 Mild Custom shoebox coupe
Discussion in 'Traditional Customs' started by Tony Ray, Sep 12, 2017.
  1. mikhett
    mikhett
    from jackson nj
    MarkIs the best at what he does!
    Tony Ray likes this.
  2. mikhett
    mikhett
    from jackson nj
    IM diggin it BIG TIME<TONY!
  3. miguel.st
    miguel.st
    from germany
    Pretty cool!
    Are you sure with the scoops on the hood? In the pictures they look a little bit too boxy or rectangular compared to the perfect flow of all the other mods.
    Stan Back and Thor1 like this.
  4. Tony Ray
    Tony Ray
    I’m going to drive it around until next winter then decide how I feel about them before I get it painted. I wanted to have it look a little aggressive on the hood, but now that the body is done and everything flows so well it’s something I may rethink later
    chryslerfan55 and Thor1 like this.
  5. Tony Ray
    Tony Ray
    Some pics Chopolds sent me.. my lancer wheel covers got the Customs by Flash treatment and were paint in the center to match, Mark also made up a lower dash panel to house my ac vents so it wouldn’t look like a bunch of hanging **** under the dash. Been having a bunch of issues with the speedo cluster and honestly I much rather have gauges that I can see exactly what the engine is doing so he took out the interior light switch(which works with new headlights switch now anyway) the ashtray and lighter and replaced them with my new Stewart Warner gauges. AC572D7D-FCDD-4742-B238-F9DEA7590EF4.jpeg 0CC4F929-7646-4FB7-A897-E52B957D60A4.jpeg 06C81734-9AD9-4683-9B83-31A989373EB7.jpeg
  6. Chop50
    Chop50
    Nice looking car with great patina. I had a built 283 (bored to 301) back in the 60's, it was very fast!!
  7. 210superair
    210superair
    from Michigan
    My ac vents in my 51 are pretty much the same.
  8. '49 Ford Coupe
    '49 Ford Coupe
    The FIRST '49 Coupe....This picture was taken in 1960.. my brother and I and some friends built..he was 18 and I was 15. '58 Pontiac Tri-Power (carbs) .. same '55 Dodge Lancer side trim. Still looking for another set for my current '49 Coupe..
    brEad, BigRRR, Thor1 and 5 others like this.
  9. Tony Ray
    Tony Ray
    Nice!!!! That trim just looks great on a coupe!
  10. '49 Ford Coupe
    '49 Ford Coupe
    I realize it may be too late, but since you are air conditioning it, you don't need those tilt out back windows, and if you can find some from a Business Coupe, which are fixed and won't leak or make noise on the highway.. I traded mine to a guy from California, who lied about "good shape" ..both gl***es were delaminated and one was broken, but that didn't make any difference to me since I went with all new gl*** all around....by the way are you going with electric windows? Bear Claw door latches?
  11. Tony Ray
    Tony Ray
    I went with all new gl*** for the windshield and side and quarter windows. Eventually I may put electric windows in it.. crossed my mind and it’s something I can do down the road. As far as the latches, Chopolds had a caprice out front of his shop that we cut the latches out of and put them in my car. Worked out pretty good!
    brEad, Thor1, chryslerfan55 and 2 others like this.
  12. 210superair
    210superair
    from Michigan
    I have ac but honestly I rarely run it, and I love my tilt out windows!
  13. '49 Ford Coupe
    '49 Ford Coupe
    By the way did you review my gallery regarding the doors? It would sure be a lot easier to do your electric windows while you still have everything all apart..
    chryslerfan55 and Tony Ray like this.
  14. Tony Ray
    Tony Ray
    I like em too.. the whole reason I got the AC is my wife was cl***ified as in stage 3 heart failure. So being in a hot environment doesn’t do her any good. So when she is with me I can pop on the ac and keep her cool, otherwise for me it’s windows down arm out window and listening to my pipes!
    brEad, Thor1, Hombre and 3 others like this.
  15. VEDETTE
    VEDETTE
    from FRANCE
    '49 ford coupé, can you tell me which front tires you bought?
    Thanks! ;)
    chryslerfan55 and '49 Ford Coupe like this.
  16. '49 Ford Coupe
    '49 Ford Coupe
    All four are Diamond Back Cl***ic III 15" radials...255/75(?) Rears and 225/75 on front... I am sure about the rears but I'm guessing at the fronts.. Actually they are BF Goodrich that diamondback grinds the lettering off of the outside surface but leaves it on the inside surface..
    And the saga of new tires
    https://49fordcoupe.smugmug.com/New-Rear-Tires/
  17. '49 Ford Coupe
    '49 Ford Coupe
    Here's the gallery for "The Doors"..
    https://49fordcoupe.smugmug.com/The-Doors/
    And maybe I'm just a big sissy, but I think I would be a little concerned about cutting those big *** holes through both sides of the frame on both rails.. since your exhaust is coming out in front of your rear tires you shouldn't have problems with it s****ing the ground unless you go really really low with your ride...
    And how about electric cutouts?
    https://49fordcoupe.smugmug.com/Fixing-Exhaust-Cutouts/
  18. VEDETTE
    VEDETTE
    from FRANCE
    Thank you! ;)
  19. Tony Ray
    Tony Ray
    I’ll check it out!
    54delray and chryslerfan55 like this.
  20. Tony Ray
    Tony Ray
    Thanks for the links! When Mark (Chopolds here on the Hamb) did my exhaust he cut the holes in my frame(it’s boxed) then welded in a pipe that the exhaust goes through. It’s all really solid and not going anywhere.
  21. Tony Ray
    Tony Ray
    Well finally got around to washing the blue off my whitewalls. Decided to take. A few pictures since I only have them of it when it was in the shop. Still got a ton of work to do yet but it’s drivable for the most part!
    B226E35D-102D-4D1F-B5DB-75514A1844FD.jpeg E0166BC3-BB94-4E9C-B7AE-AF61AAE2A304.jpeg E5B7C587-A9AD-4528-8090-DEA0B0B3DA12.jpeg 5AF617FE-F753-4EE0-A1AD-8E0C232B0BB5.jpeg 1DF34F57-6446-4004-A018-24F2859E75E3.jpeg 27C04BD0-C972-4F4A-93BC-FA3DEE75AF31.jpeg 1614331D-C86E-4AB0-904C-14F48B67F65E.jpeg FB3E1CD7-0CB6-4EAA-AA5A-CF6FEDCD78E5.jpeg F24173DD-1E14-46CF-AE1B-B41C149BF295.jpeg 6EE73743-E781-4482-B688-6AC8B1B4F3D8.jpeg 946BBE24-4812-4537-A25D-129302CCD916.jpeg
  22. '49 Ford Coupe
    '49 Ford Coupe
    WHERE did you get that 55 Lancer trim?!?! I've been looking for years..
    54delray and Tony Ray like this.
  23. Tony Ray
    Tony Ray
    I spent a lot of time on the dodge Facebook groups. Ended up getting lucky and got 2.5 sets. We put the better one on the car and the other one is going on **** “Peep” Jackson’s car owned by Octavio Chavez now.
    54delray and '49 Ford Coupe like this.
  24. '49 Ford Coupe
    '49 Ford Coupe
    So you still have the other "half set" ?? I have the two short front fender pieces....
  25. Tony Ray
    Tony Ray
    Holding on to the pieces I have for the interior.. if I go a different direction I’ll give you a shout!
    54delray likes this.
  26. '49 Ford Coupe
    '49 Ford Coupe
    You might check out my interior on this link... Be sure to watch that first video for the finished product but then the rest of this galleries all about what it took to get from there to here.. also click on the home ****on on the upper left of this gallery to see the entire 3000 Plus pictures and videos of everything I've posted to my website...
    https://49fordcoupe.smugmug.com/The-Interior/
    54delray, Tony Ray and catdad49 like this.
