Projects 51 Olds project
Discussion in 'The Hokey Ass Message Board' started by DRD57, Feb 14, 2009.
  1. 57J2
    57J2
    Very Impressive !!! Thanks for taking the time to share your work.
  2. 53choptop
    53choptop
    This is an awesome thread.
    Hey DRD57, that car wouldn't happen to have any spare door trim would it? Is the customer going with stock side trim? I need some trim for my project.
    Thanks
  3. DRD57
    DRD57
    Sorry, we don't have any of the side trim for the car.
    All the holes were filled by the last guy that worked on it and the customer wants it left that way.
  4. emil
    emil
    from sweden
    sweet thread dude!
    love the car, gonna be really nice
  5. 4rod
    4rod
    looking sweet...dig the play by play with the rear light fab work...
  6. PurplePearl50
    PurplePearl50
    from Sedalia,Mo
    Any More on the tail lights Im kinda thinking some thing like this for my 50 Chevy.
  7. Kustom7777
    Kustom7777
    from Austin, TX
    beautiful job so far,,,,,you are doing that car RIGHT!!
  8. oldsman71
    oldsman71
    looks nice!!!
  9. ot0_m0t0
    ot0_m0t0
    Nice work, How did you fix the crooked chop and sheet metal overlaping?
  10. Ole_Red
    Ole_Red
    from 206, WA
    good effort don! lovin the progress!
  11. KillerKustom
    KillerKustom
    Great looking project!
  12. El-Cid
    El-Cid
    Thanks for doing that; pointy rear quarter windows is my biggest pet peeve with a lot of chops. That looks proper.
  13. DRD57
    DRD57
    The chop wasn't crooked, it just had a lot of overlap and wavy welds. That and it wasn't finished.
    The customer didn't want to pay for cutting the top off and starting over so, we stripped it down to bare metal and did the first layer of filler in EVRGL***, kevlar reinforced body filler. Then we finished it up with Rage GOLD. The worst areas on the "C" pillar and the panel below the rear window have 1/4" - 3/8" thick filler total.
  14. RPIERCE
    RPIERCE
    from Alvin Tx
    Great work! The car is looking bad ***! Keep up the work and keep us posted.
  15. 29 de soto
    29 de soto
    this olds is *****in,nice work!
  16. bonesy
    bonesy
    The details are fine. The quarter window and tail lights are perfect. Wow!
  17. DRD57
    DRD57
    Here's an update on how the car looks now.
    Rotten Rodney has been slingin' some mud and makin' lots o' dust.
    Engine & trans are in, bags are plumbed, brakes are plumbed, Mustang tank with Astro van filler are in, hard lines for trans cooler are done, steering is done.
    I found 53 Ford headlight rings at Nightprowlers and made my own clips from .047 piano wire from the hobby store.
    I'm using 57 chevy truck headlight buckets because they were the cheapest repops I could find. It appears that most GM's of the era used Guide buckets that are all the same except for trim ring brackets.
    Next on the list is fuel line, pump, & filter, engine accessories, wiring, windows, adapt a 64 Tbird center console, primer and lots of sanding.
  18. Rikster
    Rikster
    Looks fantastic Don
    Always looking forward to an update on this car.
  19. 51fleetline
    51fleetline
  20. -TKL-
    -TKL-
    is that fully aired out?
    love the rounded corners, makes it looks soo much better
  21. DRD57
    DRD57
    When Rotten left last time, this is how the former turd looked.
    The body work was about 90% done. Between his trips I worked on mechanical things, headlight mounting, tail lights, hard lines, etc.
    This trip Rotten finished up the bodywork and we put in a marathon session to apply 3 coats of PCL primer to all body surfaces. It looks way mo bettah all in one color.
    A few days before primer, the customer stopped by to check on progress and discuss final plans for the front bumper and grill. We decided that the transition between the bottom of the hood and the top of the grill needs some work so, as soon as the primer was dry I got out the grinder and tore into it. Here's where I am so far.
    Next up is to add some transition pieces to the fronts of the fenders and finish welding up the hood pieces.
  22. DRD57
    DRD57
    We're going for this look for the bumper and grille so, if you know where I can find that top grill bar, let me know. The one we have is toast.
  23. DRD57
    DRD57
    Yes, this is how it looks aired out.
    The frame is about 2" from the ground. If you wanted to get the rockers right on the ground you'd have to channel the body over the frame. the frame hangs about 2" lower than the rockers on this car.
  24. fitzee
    fitzee
    Great post.Lots of ideas for my fleetline project.
  25. James D
    James D
    Great build up.
  26. DRD57
    DRD57
    little more progress today
    jakespeed63 likes this.
  27. Tinman
    Tinman
    from Orange, CA
    Nice detail... that really flows.
  28. 57J2
    57J2
    Thanks for the update. That's an excellent idea with the hood !!
  29. gotra66
    gotra66
    Wow, that is coming along nicely. You do great work. That hood lip really makes it flow to the grill bar nicely.
  30. DRD57
    DRD57
    We're making progress. The jambs are painted, the firewall is pinstriped and this week we're ***embling the body, hopefully for the last time, in preparation for the exterior paint.
