51 Pontiac Chieftain... No Brake Master Cylinder??
Discussion in 'The Hokey Ass Message Board' started by gavinmosher, Feb 23, 2011.
  1. gavinmosher
    gavinmosher
    Hey guys time to redeem myself lol.... i bought a 51 pontiac chieftain a very slick car all original chrome still there and a pretty straight body.... one big problem though....
    while unloading the car i noticed there were no brakes at all... i opened the hood to look for the master cylinder and there was nothing on the firewall....
    it has brake lines running to the wheels but i cant quite follow where they go to and where the heck the master cylinder is to bleed/add fluid to try to get this tank of a car to stop
    any help would be much appreciated
  2. Captain Kirk
    Captain Kirk
    Try under driver's floor. May be a fill tube under hood where hood meets windshield on drivers side. That is how it is on my 55 Cadillac, might be similar. Good luck.
    Kirk
  3. Im not too familiar with GM products, but on mopars the master is under the floor
  4. starliner62
    starliner62
    look for an access cover on the driver's floor along the frame rail. Master cylinder should be mounted on the frame.
  5. 55chieftain
    55chieftain
    The master is on the frame under the area of the brake pedel if it's manual brakes. There should be a removable floorpan piece around the brake pedal...
  6. gavinmosher
    gavinmosher
    okay i see one around all three pedals thanks alot guys i will pull it off in a bit to see what i can find
  7. gavinmosher
    gavinmosher
    any good places to find replacement steel for these old cars?
  8. gimpyshotrods
    gimpyshotrods
    Pull up the mat, or carpet and look for an access plate. I have seen a few cars that have been repaired in this area where did not bother to put an access plate back in, so be on the look-out for repairs.
    You will find (if it is original), a single-circuit master cylinder there. This is not something you really want, unless this is a restoration. One leak=total brake failure.
    This might be a good time to upgrade to a dual-circuit unit, where one leak=50% brake failure.
  9. gavinmosher
    gavinmosher
    any information on a brake upgrade would be much appreciated lol i just want to get her on the road again
  10. 53sled
    53sled
    from KCMO
    you might try EMS.
    Walton Fab, The Filling Station, ECI can help you out.
  11. gavinmosher
    gavinmosher
    EMS? sorry im new to the sheetmetal and old parts
  12. garvinzoom
    garvinzoom
  13. garvinzoom
    garvinzoom
  14. 55chieftain
    55chieftain
    Scarebird makes a bracket kit for disc brakes and also a bracket to mount a dual chamber mc in the factory location.
  15. markjenks
    markjenks
    There's a master there somewhere. Get it up in the air and look under the car by the gas/brake pedal.
    There is usually a rubber plug right around the gas pedal under the carpet.
    If my 40 Pontiac's have one, the 51 has to have one.. :)
  16. unclechop
    unclechop
    Its under the steering column in the engine bay.
  17. ems customer service
    use chassis engineering in iowa
  18. davidbistolas
    davidbistolas
    Also, you may find it easier to search for 51 chevy. Lots of interchange.
    Is this a power glide car or three on the tree?
    As said earlier, It's under the drivers floor.
  19. 5150Pontiac
    5150Pontiac
  20. 5150Pontiac
    5150Pontiac
    The master is on the frame rail under the driver floor!
  21. The last time this guy posted about this problem it was last february..I'd imagine he found the master cylinder in almost a year.
  22. Why did they hide, that is the only word for it, the master cylinder?
  23. That's where the pedals went!
