Hot Rods 51 Shoebox Steering Shaft Movement???
Discussion in 'The Hokey Ass Message Board' started by thekid1950, Dec 25, 2022.
  1. thekid1950
    thekid1950
    I have a friend with a 51 Ford Wagon modified with a Volvo steering box. When he grabs the steering wheel and pulls up the steering shaft moves up about 1/4" inch.
    I know this modification requires cutting and welding the bottom end of the steering shaft. There must be a bearing or a bushing that is either loose or maybe a threaded nut under the steering wheel that is loose.
    Any ideas where to look?
    Thanks
  2. badshifter
    badshifter
    Yes. At both ends. Without knowing how it was modified, and no pics, the problem could be dozens of things. Rag joint? U joint? Loose collar on the firewall end? Bushing? Bearing? Too many unknowns.
