Technical 51 styleline front end driving me nuts
Discussion in 'The Hokey Ass Message Board' started by Chuck mazz, Jul 17, 2017.
  1. Chuck mazz
    Chuck mazz
    image.jpeg Ok guys I'm new here and I hope I post this in the right place but I just picked up a 51 styleline 4 door. The front end is driving me nuts. Soo I picked the car up with flat tires and rat turds. Get her home air the tires up, go over the brakes, clean the carb and fuel tank and toss a battery in. Boom she's running and rolling on her own oil leaking power. Soo not sure if it was like it or not when I bought it couldn't tell with the flat tires but I hit a sewer lid that was not in place and well now my problem starts. So I bent the control arm and tie rod and found a guy who had a whole front cross member so I robbed it of parts and slapped mine back together. And the camber was still horrible on the driver side wheel I'll put a pic up as well. So I realize the whole cross member is bent so I change it out and it got better but the camber is still excessive. I'm lost now. I'm thinking the frames bent and I'm kinda screwed with a bent frame. Anyone has this issue before?
  2. F-ONE
    F-ONE
    from Alabama
    Take it to a front end shop, they do that for a living. You may need to go to a truck shop that services trucks. Call around.
  3. 325w
    325w
    Did you change an upright.,they will bend.
  4. Chuck mazz
    Chuck mazz
    Tried to find a shop that would do it and no luck so far. Nobody will even look at. Claiming it's too old. There machines won't do it blah blah
  5. Chuck mazz
    Chuck mazz
    I did replaced that whole front end with a known good one. I did notice that the drivers front seems to be extended to the bump stop. The p*** after side is sitting lower with about 2 inches to the bump stop. The rear seems to sit about a inch different side to side
