52-54 Customline rear wheel arch shape
Discussion in 'The Hokey Ass Message Board' started by MickD, Apr 23, 2012.
  1. MickD
    MickD
    Hey guys, I'm attempting to rebuild the rear wheel arch on my 52 Cussy. It was so badly eaten away that I can't get an accurate shape of the curves of the arch on the right side. I've made a template from the left side, which is still a bit of guesswork, because it's not a great deal better than the right side! I think I've pretty much got it now, but what I'd really appreciate is if someone with a 52-54 Ford could squat down and take a close up direct side on view of his RHS rear guard arch with a camera, and post it on here, I'd be forever grateful to him & I'll dance on his grave!.
    My plan is to copy & print the photo, transfer it to grid paper & make a full scale template on some cardboard or MDF board so I can get the shape right. I know it won't get me the angle of the curl under, but I can get that from the left side.
    Thanks guys,
    Mick
  2. Take a look at my photo album listed below,there are a lot of pictures of the wheel well areas that were repaired. HRP
  3. MickD
    MickD
    Thanks man. There's a few good ones there. Geez...! You've been a busy boy with that wagon. That's a helluva restoration job. You gotta be pretty proud of that! I don't think my workmanship is in the same ballpark! I wish I had your talent!
    Cheers,
    Mick
  4. Another Idea is to locate a good fenderskirt. I have a NOS set I would be bappy to make a tracing for you and drop in the mail. I will attach a photo of another option with a radiused wheel opening
  5. Squablow
    Squablow
    I did my Edsel ones using a pair of fender skirts like loveoftiki suggested, worked really well although they might be hard to come by in Oz. If you didn't get what you needed from Hotrodprimer's build pics, let me know and I'll snap a couple of my '52 parts car.
  6. MickD
    MickD
    Thanks guys. "Loveoftiki, by NOS I guess you mean new old stock yeah? They'd be something like hen's teeth here in oz. Radiused wheel arches... they look like a good idea. Is that your build in the photo? Thanks for the offer to make a tracing. I've got a few good pics from Hotrodprimer's build and a few others I found surfing around, so don't get your pencil out just yet. To post something like that from the states to oz might cost a bit bigger than a normal post and I wouldn't want you to spend your hard earned just for me. But it's nice to know there's still a few of us good guys around spread around this big ol' tennis ball
  7. EchoOfGecko
    EchoOfGecko
    Don't forget to join up with the '52-'59 Ford social group! Lots of great info over there, and a million '54 Ford pics that might help out. Plus, we all like seeing new Fords in the group. :)
  8. jdownunder
    jdownunder
    hey pa im warming to the radius arches just have to make them gentle if you know what
    im mean.pm me some shot of them.hey have you noticed there all two doors or 90% of
    them on here.food for thought
  9. MickD
    MickD
    I don't have ta send you a shot of them. Get off your arse my boy & get up here. You'll see them when you get here. Anyway, I've got some welding for you to do! (P.S. How long have you had that avatar?)
    Your loving father.
  10. kari613
    kari613
    Hi, Mick, Just use a pair of correct skirts to form the wheel well radius. I did this on my 56 Dodge. I welded in 5/16 rod to form a strong arch and then wire welded in new steel. The skirts fit perfectly, Bill
  11. MickD
    MickD
    Good idea Bill. My only problem there is I can't readily get my hands on a pair of correct skirts. Actually I'm going around it the long way a bit. I cut & shaped halt a dozen strips of cardboard at 4" apart on the good side & measured from a straight edge which I marked half way up the guard & I transferred those across to the other side. so it's measure -bend- measure - bend cut- measure- bend.... it's actually starting to take up the right shape. a few coffees & beers later I might just get it right. Got plenty of time :) And thanks guys for the advice. I 'spose I should get a few build pics up. "EchofGecko", (I hope ya mother didn't christian you that!!) I'll probably join up soon.
