1952-59 Ford 52-54 hood hinges
Discussion in 'Off Topic Hot Rods & Customs' started by westcoaster, Feb 2, 2010.
  1. westcoaster
    westcoaster
    from SoCal
    anyone out there rebuild them yourselves? i know these hinges are a sore spot on these cars. i remember hearing of a guy who rebuilds them, but can't find his info. i think he is in burbank, ca. anyone.
  2. 1hot1954
    1hot1954
    from Reno, NV
    Hood Hinge springs brand new made from NOS paterns and full restore of your hood springs
    Rowland Hall
    1901 Jackson St.
    Burbank, CA 91504
    (818) 845-3574
    rowlandhall@mindspring.com
  3. Rowland told me the other day that all he does is rebuild your old hinges. Charges $325.00 a pair.
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    If you have cores to sell contact Him also,I sold Him some a while back.
  5. westcoaster
    westcoaster
    from SoCal
    has anyone here had him rebuild your hinges. what does a rebuild consist of?
  6. westcoaster, if you e-mail him and ask He will send you a attachment detailing the procedure
  7. 1hot1954
    1hot1954
    from Reno, NV
    I talked to him last summer and it sounded like he actually reinforces them along with rebuilding them.
  8. westcoaster
    westcoaster
    from SoCal
    this is what he sent me. i'll be sending my hinges to him. just need to save up a little more scratch. i'll post before and after pics for you guys.
    1952-1954 FORD HOOD HINGE
    REBUILDING PROCEDURE
    HINGE ARMS
    1. Remove rivets-Grind off rivet tails inside of air box.
    2. Remove all rivets.
    3. Straighten arms.
    4. Install and weld bushings in arm to hood mounting holes.
    5. Gl*** bead all arms and air box.
    6. Make new flat coil spring anchor (two flats and slot)
    AIR BOX
    1. Check arm seats on air box for flatness.
    2. If seats are not flat, straighten seats.
    3. Add 3/16-in. thick reinforcing plate to inside of air box.
    RIVETS
    1. Manufacture new steel rivets.
    2. Hand fit rivets.
    3. Install rivets with thin flat steel washer between rubbing arms.
    SPRING INSTALLATION
    1. Install flat springs
    2. Install coil tension springs
    Price--$325.00 per pair
  9. Nite Owl
    Nite Owl
    Mine just came in the mail. When I opened the box, I just had to yell yippeee!!! These bad boys are just awesome. He did exactly what westcoaster posted above. The reinforcement should be a tremendous help. And besides that, I have talked to him several times and he is genuinely a nice guy. I highly recommend him.
  10. skoh73
    skoh73
    Could you post some pics? I'd like to see them.
    Thx
  11. Nite Owl
    Nite Owl
    I would really be happy to if I knew how. I am technologically challenged. I'll try and get my grandson to help me.
    Butch
  12. skoh73
    skoh73
    Thanks Butch, no rush-get to it when you get to it.
