52 chevy alt mount issue HELP!!!!!
Discussion in 'The Hokey Ass Message Board' started by CARLOS8A, Feb 22, 2010.
  1. CARLOS8A
    CARLOS8A
    from waukegan
    ok so I have a chevy 305 in my 52 chevy, and Iam running a short waterpump and I have stock manifolds so I cant use the header mounted alt brackets!!I ordered a low mount bracket and that wont work either. so now the only other way to go about this is using a upper mount on the right hand side like it came stock, but now I would have to go back to a long water pump!!! so I was hoping someone could help me find a solution i wanna keep my short water pump but it looks like i have to run the long one pics would help allot thanks!!!
    here are some pics of the motor to try and give a idea!!
  2. CheapSheep
    CheapSheep
    Make 'em yourself!
  3. CARLOS8A
    CARLOS8A
    from waukegan
    REALLY??? Is that the best you can come up with??? WOW!!!
  4. CheapSheep
    CheapSheep
    Yepp, damn sure is. Once a week there is a new "alt mount, help me"-thread, but if people just figured my answer out themselves, they wouldn't have to ask! If you can swap an engine, you have the skills to build friggin' alt mounts!
  5. dbradley
    dbradley
    Pretty sure Allen Grove makes one that will work. I use them on my '33. Bolt to waterpump and intake manifold. Top of driver's side mount.
  6. CARLOS8A
    CARLOS8A
    from waukegan
    dbradley: would you by any chane have a picture of it?? or a website?? thanks allot for your positive input!!
  7. tooslow54
    tooslow54
    +1 on Allen Groves. That's what I used. About $70, so if you have the skills you can make 'em or order it from Allen. Mine fit perfect.
  8. flatheadfever
    flatheadfever
    I have the same problem.
    I am going to try a 79 corvette bracket also used on 69-72 trucks.
    I might have to cut the mount off my right manifold.
    I could also modify the generator bracket and make that work but I do not want to hang the weight on the manifold.
    It is a hit and miss learning mission for myself as well.
    I have found a ton of great info on the HAMB doing searches!!
    This is probably the best way to go
    Alan Grove http://www.srbymichael.com/manufacturers/alangrove/agrove_sbcswp.shtml
  9. squirrel
    That would be my suggestion.
  10. CARLOS8A
    CARLOS8A
    from waukegan
    thanks guys!!! anyone have pics of there setup??
  11. the Alan Grove one is good, i have used several of them
    So-Cal make a simple one that bolt to the short water pump and intake bolt , puts the alternator on the p***enger side above the intake. they are about $50....but would be easy to copy. i have a copy of one on my `36 , and the one i bought for a pattern in now on my `29 pickup project
    Speedway Motors has a similar one , puts in in the same location. it's basically a copy of a mid 70's smog pump mounting bracket. i have one on my `28 Tudor
  12. tooslow54
    tooslow54
    I can post a pic of mine, but I don't have them here at work. I'll post it up tonight if you're still looking. The So Cal one looks good too.
  13. Mr48chev
    If there isn't enough space on the side to mount it you can use a smog pump bracket to mount it above the water pump. You will probably have to come up with an idler to keep the right tension on the belt though. I had that setup on the 283 that I had in my truck years ago.
    It mounts pretty much the same way that the Allen Grove one does.
  14. CARLOS8A
    CARLOS8A
    from waukegan
    that would be great if you can do that!! thanks
  15. 53sled
    53sled
    from KCMO
    a long bolt, some washers and heim joints for the adjuster.
  16. CARLOS8A
    CARLOS8A
    from waukegan
    So I ended up ordering this bracket kit from speedway hopefully this will work out!!! thanks for your help guys!!
  17. Steves32
    Steves32
    from So Cal
  18. CARLOS8A
    CARLOS8A
    from waukegan
    that is exactly what I did, ordered the plain one. I was thinking of doin like a stainless paint on those brackets... what do you think?
