Technical 52 chevy driveline swap
Discussion in 'The Hokey Ass Message Board' started by lowroder, Mar 15, 2017.
  1. lowroder
    lowroder
    Ok Guys I Know This Has Been Discussed A lot...Cant Seem To find Any old Threads On This ....
    I Bought A 1957 Rear End To Swap Out My Original Torque Tube 1952 chevy coupe. To Open....
    I Know 57 rear.jpeg It Should Be A Direct Bolt In... What Other Mods Needed To Start The Swap ??
    Thanks Guys
  2. gimpyshotrods
    gimpyshotrods
    It is not a direct bolt-in.
    If you take a close look at where the centering pin (aka: the bolt that holds the leaf pack together) is in relationship to the axle centerline, you will find that it is not directly under the axle.
    It is under the pivoting perch that your current axle attaches to, which is forward of the axle centerline. If you simple mount the '57 axle on that pin, your wheels will be abnormally forward.
    You will need to figure out how much farther forward the pin is, and drill a new hole in each perch on the '57 axle, forward of the original '57 one. Mount it in that hole.
    Nailhead Jason and lowroder like this.
  3. gimpyshotrods
    gimpyshotrods
    lowroder likes this.
  4. Chavezk21
    Chavezk21
    I believe it is 1 5/8's inch. I seem to recall that on my uncles 51.
  5. 51pontiac
    51pontiac
    from Alberta
    Same thing I have, so many years ago that I don't remember the exact distance the pin is offset but you will also need to get some ubolts built, not a big deal.
    The springs spread out ever so slightly if I remember correctly but work fine.
    I rigged up an emergency brake system using the original pull handle.
    Just a suggestion, replace the flex hose to the rear axle.
    Hope this helps a bit. This has been under my car (1951 Canadian Pontiac - same frame as Chev) since 1977 or so and has worked well.
  6. 56sedandelivery
    56sedandelivery
    In this case, the pin hole is re-drilled 1-1/2' forward, and 1/2' inward. We did our 51 Bus Coupe with a 56 housing using those measurements. You could re-drill the hole the 1-1/2' forward, and leave it at that, then see if the leaf springs seem to "lean" one direction or the other (inward or outward), and go from there. We used some new overload shocks with coil springs surrounding the shock, meant for 55-57 Chevrolets, and that took care of any tendency for the car to sway back and forth (the stock springs are kind of narrow, the torque-tube taking the brunt of rear end stability). We also used ******* bar type traction bars set with a close contact on the snubbers. The stock leaf springs worked fine doing this. If you have the extra $$$ for the aftermarket leaf spring kit, then go for it. I am Butch/56sedandelivery.
  7. Rusty O'Toole
    Rusty O'Toole
    51 Pontiac does your Pontiac have the same rear axle as a Chev? I need to know this because I need gears from a Powerglide Chev with torque tube, if Pontiac is the same that expands my field of search.
  8. 51pontiac
    51pontiac
    from Alberta
    Yes, the lower levels of Canadian Pontiacs had the same frame as the Chev, same torque tube rear end to the best of my knowledge and same front suspension. They did have a flathead 6 engine however with a different bellhousing but I believe the same transmission. I originally put a 235 in the car bolted to the stock ****** and rear, swapped to a 235 and powerglide with the '57 rear and now 350/350 combo.
  9. Yes sir, those 1 1/2" x 1/2" measurements are right on !
  10. Rusty O'Toole
    Rusty O'Toole
    Thanks, could be a big help in finding parts.
  11. Devin
    Devin
    from Napa, CA
    I think if you are going to be putting significantly more power down, you should ditch the OG leaf springs as they are narrow and noodley since they only had to locate a torque tube rear end. You will have significant axle wrap otherwise unless you engineer a torque arm etc. the effect will be further magnified if you decide to use lowering blocks also. Ch***is Engineering has complete setups with new shackles mounts and springs. I know a lot of people stick with the stock springs, this is just my take on it.
  12. Devin
    Devin
    from Napa, CA
    I put a '57 Chevy rear in the ch***is of my '50. I am using c10 truck arms and a panhard bar for location. This would be a really hard swap to do with the body on frame however. Other alternatives are 4 links etc.
  13. lowroder
    lowroder
    thanks butch
  14. lowroder
    lowroder
    Keeping The OG 235....
  15. lowroder
    lowroder
    Inward from outside to middle ...or middle (driveshaft side) to outside?/ I understand the forward hole . However I ***ume its from center hole forward 1 1/2
  16. Go forward, towards engine, one and one half inches.
    Then go inward. towards driveshaft one half inch.
    As said here somewhere, you may not need to do the one half inch inward.
    See how the rear end sits on the springs, if the springs are pushing or angling outward, towards the wheels, with the spring locator pin in position, then be sure to do the one half inward step.
  17. lowroder
    lowroder
    Ok So Should I Prefit The Rear End On Springs Before I Drill Any Of The New Holes? I Know I Will Still Need To Drill Forward To Center It Up Correctly..
  18. gimpyshotrods
    gimpyshotrods
    Yes.
    Before drilling anything, toss it in there and see if you can get the pins into the stock holes, side-to-side, easily, if not, put one in and make a note how far off the other one is, cut that number in half. That's your offset, per side.
    Drill forward, and sideward accordingly.
    Old-Soul likes this.
  19. Lowroder, you have to drill the new holes one and one half inch forward, for certain.
    That will center the tire in the wheel opening ( front to rear ), as you said.
    BUT, if you just drill forward and not the one half inch inward and do the fit, you may not have enough room to drill a second hole inward, if you need to do so, being that you have already drilled a hole, in the forward position only, on the pad.
    Going forward one and one half inches, then 1/2 inch inward gives you ONE drilled hole ...... if you do it forward only, then NEED the inward hole drilled separately, now you have two drilled holes.
    Problem here is, with two holes drilled so close to one another, in your two step process, the holes may interfere with one another.
    I hope that makes sense to you, tougher for me to explain in writing, instead of being there with you.
  20. lowroder
    lowroder
    cool..thanks guys for all your help...
  21. lowroder
    lowroder
    ok so if I don't go with this adaptor piece to keep my original ******...whats a good trans for this rear end it has a 3:36 according to the tag on the center bolt section
  22. jose gonzalez
    jose gonzalez
    good info keep it coming i have a 52 hard top 3 speed would like to convert it powerglide with 55 thru 57 rear end
