52 chevy rearend swap?
Discussion in 'The Hokey Ass Message Board' started by matthew mcglothin, Oct 10, 2007.
  1. matthew mcglothin
    matthew mcglothin
    well im tearing out the old six and old tourqe tube. im replacing it with a chevy 350\350 combo. any body have any rearend suggestions that will fit my car. im still running stock steelies. and i think the stock rearend width is 60in.
  2. John Denich
    John Denich
    I am using a mid 70's nova in my car! works perfect!
  3. This guide should help...http://www.carnut.com/specs/rear.html
    Are you keeping the stock leaf-springs? If so, the 70's Camaro and Nova rears are practically a bolt in. All you need to do is re-drill the perches on the rear (or make blocks and drill those)...1.5" forward from the stock location to compensate for the offset locating pin on the stock springs.
    Bryan
  4. PurplePearl50
    PurplePearl50
    from Sedalia,Mo
    got a nova in mine with 2.73 or 2.72 gears some thing wild it gets great gas mileage
  5. 49ratfink
    49ratfink
    got a 65 nova rear in mine... nice and short. that chart Rusk posted is a good thing to have around, though I didn't see the popular S-10 rears mentioned.
    had a 70-78 camaro rear in my old one... I couldn't run my skirts with the wheels I had.. pretty sure they were 15x6.
  6. matthew mcglothin
    matthew mcglothin
    thanks for the help guys!!!
  7. Me too.
    There's another chart on http://www.50chevy.com...I think it lists the years for the S10 4x4 rears.
    Bryan
  8. gas pumper
    gas pumper
    54-210, 76 Nova, 2.93 gear. real good. even the park brake hooks right up. I think when I welded on new spring pads, I drilled the center bolt hole in a different place to center the wheel in the wheel opening.
    Even the Nova driveshaft fell right in. right lenght. The Nova had an auto and i got a Saginaw.
    Frank
  9. roach motel
    roach motel
    55 chevy with full airride under mine. fits perfect.... no problem tucking.
  10. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    what they said.:D
  11. Lots of threads on this - these all work if you relocate the hole for the pin:
    55-57 Chevy
    70-81 Camaro/Firebird
    75-79 Nova and clones (have not been able to find out if the 68-74 rear is the same or not)
    82-up S10 4x4
    Many others will fit but may need perches moved or added, or will have the wrong bolt pattern for the wheels.
  12. 40chev
    40chev
    I have a 70's nova rear for my 40, I bought new leafs and hangers from Ch***is engineering for this rear end so all I have to do is bolt it in, I wont have to cut the perches, do any welding, just bolt in and go......
    hers a link for your car
    http://www.ch***isengineeringinc.com/page31.html
