1952-59 Ford 52 Custom sedan - run's warm
Discussion in 'Off Topic Hot Rods & Customs' started by dougert7, Aug 7, 2012.
  1. dougert7
    dougert7
    hello,
    Just got my 52 running a week ago, noticed that is has been running at the top edge of the "normal" bar on the gauge. The t-stat seems to be opening, should I just replace it with a lower heat range or maybe its the 3 blade fan (oem) that is falling short? any idea's? Its got the straight 6 in it.
    Thanks!:confused:
  2. the-stig
    the-stig
    Welcome from So Cal. I would say a fan with more blades and a fan shroud.
    I'm sure someone will let you know exactly what you need to cool your car. Good luck.
  3. paleot
    paleot
    from louisiana
    I have the stock gauge in mine, it showed the upper range toward hot I checked it with two different manual gauges both showed about 170 deg.
    Tony
  4. dougert7
    dougert7
    my fan runs right next to the radiator, I will have to check it with a manual guage, thanks guys!
  5. bigshawn
    bigshawn
    Check gauge Had same problem in my 52 last year. also got myself new radiator .
