Projects 52 Dodge B3B Hemi Project
Discussion in 'The Hokey Ass Message Board' started by 70chall440, Oct 10, 2012.
  1. George
    George
    There is specialty oil for break in with ZDDP in it.
  2. 70chall440
    70chall440
    I got that part, was looking for brands, weights actually.
  3. Brand Apart
    Brand Apart
    from Roswell GA
    JOE GIBBS & lUCAS ARE THE ****
  4. George
    George
    Can't make specific recommendations, but as long as it has the Zinc, I'd go with as thin an oil as they have.
  5. 70chall440
    70chall440
    awesome, thanks. Any recommendations on weight? I am thinking 10-30.
  6. 70chall440
    70chall440
    Here are some pics
  7. 70chall440
    70chall440
    Another - lokar linkage
  8. 70chall440
    70chall440
    This is the top part of my trans cover, 4 parts in all. I made a metal mopar "M" which is bolted to the plate.
  9. 70chall440
    70chall440
    I mounted the fuel pump to the p***enger side inside frame rail.
  10. 70chall440
    70chall440
    the headers were a tight fit but worked out well. I will have to reroute the p*** side front break line but other than that it is ok.
  11. 73RR
    73RR
    Most engine builders will use straight 30w...not even sure if oil labeled as 'break-in' is available in multi-weight.
    Be sure to change the oil after the first hour or two and cut the filter open and look around.
  12. 70chall440
    70chall440
    thanks Gary, I have a local machine shop that carries Joe Gibbs break in oil, so I will probably use that. I don't know if there are multiple weights or not but I will see what they say.
  13. 70chall440
    70chall440
    Been trying to keep moving on this truck, I bought the stage 8 fasteners with the locking tabs, however the tabs don't work on an old hemi bc of the way the tubes and bolts are laid out. Therefore I came up with an alternate solution; drilled a small hole in the corner of the locking tab and safety wired them..
    Yes the header is close to the steering support but it isn't hitting.
  14. 70chall440
    70chall440
    I also got the pinion angle set, rear perches welded and am now working on the u joints. I am going to build some kind of snubber while I am back there as well.
  15. 70chall440
    70chall440
    got the snubber built, then realized I did so with the rear suspension hanging... so I had to go back in and rebuild it so I had clearance at ride height. Got the fuel regulator mounted, so now it is back to the wiring and running the fuel lines. I would have got more done but I had to cut up an old Leer topper that was an eye sore.
    Today was definitely "one of those days"; broke my new Dodge coffee mug first thing, then I broke the hood ornament off my new Kubota tractor, then the snubber deal, and on it went...
  16. 70chall440
    70chall440
    The suspension is unloaded in this pic which is why there is so much distance. I am thinking I am going to have to run some air bags. Problem there is space.
  17. 73RR
    73RR
    ...'ya know, if you keep this up you'll get the truck finished... then what will you do?:p
  18. 70chall440
    70chall440
    lol, not exactly something I worried about at this stage. I still have my Cuda and 70 Roadrunner to do. That said, I just found a 48 Dodge 1 ton with flatbed locally for $1150... and a 48 COE for $3k... I am kidding, I have more than enough to do as it is and to be honest I am getting a little tired of fabricating. I need to get this truck done and off my lift.
  19. 70chall440
    70chall440
    Built this cool fuel filter bracket
  20. 70chall440
    70chall440
    found out that the lokar shifter instructions are a bit lacking for the 727, while mine shifts, it isn't hitting the right gates so I need to spend some time adjusting it. Got the engine wiring done today, also got the fuel regulator installed and 1/2 of the fuel line made and installed.
  21. 70chall440
    70chall440
    My new switch panel
  22. inspectorcurly
    inspectorcurly
    Be careful of the front ride hight I fabbed in a 78 Trans Am subframe in my 52 B2B and did not consider ride hight all is good but too low was forced to make a progressive angled body lift of 2.5 inches at front Radiator support to stock at the back of cab to keep the fenders from s****ing the tires when I turn then replaced the front springs with 800lb racing springs to control the bumpidy and s****e from there everything else snowballed now 10 years later I am going to redoo it all again to make it more cruiser friendly and not beat you to death with the heavy springs.
  23. 70chall440
    70chall440
    appreciate the information. Currently I am using stock front springs which I did cut a little. It is low all the way around and it could be too low but time will tell. I do have a back up plan which is to replace the front springs and bag the rear if need be.
  24. 70chall440
    70chall440
    Got most of the fuel line done
  25. 70chall440
    70chall440
    Here is what the new switch panel will look like
  26. 70chall440
    70chall440
    I still have to get the heater core sorted out, I "believe" it leaks some and I have some sealer that I have on good authority works well.
  27. 73RR
    73RR
    Aluma-Seal has always worked well for me.
  28. 70chall440
    70chall440
    Might give it a try. I am going to try this Moroso Ceramic seal; a friend of mine in the resto business has been using it frequently and says it has worked well for them. the difference though is that they use it on a running vehicle, I have to rig something up to heat the water and pump it through the heater core.
  29. 70chall440
    70chall440
    Got the fuel lines done and half of the trans lines. I ordered some of the "mag daddy" devices, going to see how they work out. They look pretty cool and beat drilling holes everywhere.
  30. 70chall440
    70chall440
    I finished the trans hard lines, I will use soft like from them to the trans cooler once I get that installed.
