Projects 52 Dodge B3B Hemi Project
Discussion in 'The Hokey Ass Message Board' started by 70chall440, Oct 10, 2012.
  1. 70chall440
    70chall440
    I have looked a number of other diagrams and it is all a bit confusing; I am beginning to develop a sense of the concept of what has to happen but feel like I am missing something (obviously since it doesn't work). I did try and rewire the system to the below schematic but with the existing (above) still in place I believe I had doubled the wiring (2 feeds to the fields).
  2. 70chall440
    70chall440
    somewhere I am missing something as no matter what changes I make it still isn't charging, factor in burning out a regulator and/or alternator and I am chasing my tail here.
  3. 70chall440
    70chall440
    Here are some pics, first time the truck has seen daylight in awhile.
    exterminator likes this.
  4. porky55
    porky55
    That's right. If everything is connected well it should work. That's the same way my dodge is wired. Its worked great for two years now
    Sent from my MB886 using H.A.M.B. mobile app
  5. George
    George
    Upper ex manifold bolts go into oil.
  6. 70chall440
    70chall440
    I sealed all the bolts but perhaps not good enough.
  7. 70chall440
    70chall440
    this first diagram or second?
  8. porky55
    porky55
    The first diagram. I used a speedway wiring harness. That's how they had it wired.
  9. 70chall440
    70chall440
    I am using the same harness. Ok well then I have something wired wrong. I need to figure out what is supposed to be doing what and trace it all back.
  10. 70chall440
    70chall440
    no joy thus far, I had the alternator check, it is fine, bought a new VR (no way to check it), ensured all of the wires were tight, check continuity of the field wires, traced the "alternator exciter wire" back to the fuse block and check its continuity (which seems to be grounded).
    I am out of options/ideas. it has to be something fairly simple but I cannot figure it out.
  11. 70chall440
    70chall440
    So I am looking at a diagram, it is showing one of the field wires going to/from the ignition. I suspect this is my mystery exciter wire which when I just checked it (with the negative cable off and for continuity) appears to be grounded. I will connect the negative cable and turn on the ignition tomorrow to see if it has power as I believe it should have.
  12. 70chall440
    70chall440
    another issue is that I have always been told that the fld wires can be either side, however an article I am reading says there is a difference between the - and + sides, so I will switch them around as well and see if that matters.
  13. 70chall440
    70chall440
    this is the diagram I referenced above.
  14. porky55
    porky55
    OK I had a chance to look at my car this morning. The red wire runs to the bolt of course. Then the white wire goes to the nearest terminal. Then the one you ad, in my case green wire, goes to the farest terminal. 1403455375840.jpg 1403455390010.jpg
    Hope these are clear enough. I was trying to take them in the garage.
    I'm using standard brand altentor and voltage regulator. With factor Chrysler plug on the vr. Hope this helps.
  15. 70chall440
    70chall440
    appreciate the pictures and you taking time to get them. the question is, where do the 2 field wires go relative to the VR. Do you know if the white wire is going to the top post of the VR or the side? What I am seeing on many of the diagrams is that the top/center post of the VR goes to the position where you have the white wire.
  16. porky55
    porky55
    I have the white wire going to the top of the regulator. my added wire(green) is going to the side.
  17. porky55
    porky55
    This is the picture out of my kits instructions. Very similar to what you had. 1403460197911.jpg
  18. 70chall440
    70chall440
    If I cant figure this out I am going to have to rewire it to a different system such as this
  19. 70chall440
    70chall440
    those instructions are exactly the same as what I have, so in theory it should work. Before I put the hemi in the truck (when it had the 6 cyl) it had a GM alternator which worked/charged after I installed the speedway harness. Therefore it has to be something with the Mopar system. I am going to do some checking here in a minute and will see if I can get some ideas.
  20. porky55
    porky55
    Let us know what happens. Wiring is always my least favorite part of cars.
  21. 73RR
    73RR
    Here are a couple to compare to:
  22. 70chall440
    70chall440
    Thanks Gary. I am about to retest the system after a couple of changes, so we will see.
  23. 70chall440
    70chall440
    First, thanks everyone for your help. It was just one of the many "dumb***" moments of this build. Turns out that I had the wires switched on the VR which in turn destroyed the VR. fortunately I had a spare laying around and after wiring it exactly like the diagram (duh), I connected my spare and grounded it and "bam" it worked. Went back and tested the others to include my new Mopar and O'Reillys VR and sure enough, both were shot.
  24. porky55
    porky55
    Good to hear its fixed. Sorry for the casilties
  25. 70chall440
    70chall440
    Thanks. Got a couple more small issues but it is coming along. The largest is an noisy lifter on the right side; we adjusted it (one of them) and it will get quieter as it warms up but I think it needs adjustment.
  26. 70chall440
    70chall440
    Have to adjust the fenders, they must have started with the cab and adjusted everything from that back in the day.
  27. 70chall440
    70chall440
    Havent got much done lately on the truck but will soon. I need to get those pushrods adjusted.
  28. 70chall440
    70chall440
    I was going to post a video of the truck running but it seems this app won't let me :(
  29. 73RR
    73RR
    ...maybe one of the 'younger' IT guys could help...hint..hint..
  30. 70chall440
    70chall440
    perhaps someone knows. I tried to cut and paste which didn't work. uploading a file doesn't seem to work and the media ****on would let me browse.
