Probably, assuming it’s a repo gasket. Just not quite the right size is typical. I would trim it. Sent from my iPhone using The H.A.M.B. mobile app
I had to trim mine and glue it down so it wouldn't move around and leak. I razor bladed it, glued the ends and bottom..couldn't close the vent before the fix...worked great after. Good ole Taiwan "close is good enough" stuff...
Best as I can remember the screen is attached with screws . Remove the screws separate the pieces install the gasket between the screen and vent with the screws Sent from my iPhone using The H.A.M.B. mobile app
