Technical 52 ford f-5 engine
Discussion in 'Traditional Hot Rods' started by Bart78, Oct 16, 2013.
  1. Bart78
    Bart78
    What flathead would have been in a 52 f-5? I found a truck and was going to try and get the motor out.
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Probably a 337 Lincoln. If so, the distributor would be in the rear.
  3. Carter
    Carter
    I would say 239. I think the 337" 'Lincoln' engine was in the F7 and F8.
  4. Dale Fairfax
    Dale Fairfax
    Definitely the 239. The 337 was used only in F-7,8. And in spite of all the anecdotal information floating around, there is no evidence in Ford's literature (Parts catalogs, shop manuals) that the 255 Merc was ever installed (at the factory) in any trucks.
  5. V8 Bob
    V8 Bob
    The '52 F-1 through F-6 trucks used the standard 239" flathead, while the F-7/F-8s used the new ohv Lincoln-based 279" or 317" V8s.
  6. Bart78
    Bart78
    I was thinking it was a 239. But did not want to make the guy an offer and it be the 337. He said it turns over when you hook a battery to it. And hauled hay with the truck in the eighties.
  7. R Pope
    R Pope
    Canadian Merc trucks had 255's. I have a shed full of 'em!
    Plus, in the '50's and '60's, when you bought a rebuilt flattie from Ford, here in Sask. at least, for a truck, they gave you a 255 engine.
