1952-59 Ford 52 gauges with ford 302
Discussion in 'Off Topic Hot Rods & Customs' started by skunk victim, Feb 9, 2012.
  1. hey guys, ive searched and cant find my exact answer. i have a 52 meteor (ford) and i really want to use the gauges. besides changing it to work with 12 volt what can i do about sending units and does anyone have a wiring diagram or even a picture of how the 52 gauges are wired?
    thanks in advance.
    keith
  2. JeffB2
    JeffB2
    from Phoenix,AZ
  3. FlatHat
    FlatHat
    Using any of those resistive "regulators" will work, but the results won't be particularly accurate. With a resistive setup, the voltage to the gauges will fluctuate with the battery voltage.
    A better way is to use a simple and very inexpensive solid state voltage regulator that will keep the instrument voltage steady all the time. This is what I did on my '53 when I went to 12 volts, and it's worked flawlessly for quite some time. A single regulator runs the fuel gauge, the coolant temperature gauge, and the oil pressure gauge.
    If you send me a PM with your e-mail address, I'll send you the circuit, pictures of my ***embly, and some wiring diagrams that cover the instruments.
