Customs 52 hornet electrics
Discussion in 'The Hokey Ass Message Board' started by mrquickwhip, Jan 16, 2015.
  1. mrquickwhip
    mrquickwhip
    i know this may sound dumb but I've bought a 1952 Hudson hornet non runner no battery. Can anyone tell me is it 6v or 12v and is it positive or negative earth. I've looked on line and it's saying 6v but doesn't say if it's positive or negative earth. I'm in uk so they aren't common over here....Bob
  2. 64gal
    64gal
    Hi, I don't know,but if you check the points wire from the dist. to the coil, if that wire is connected to the positive side of the coil then it is positive ground.
    If the points wire goes to the negative side, it is negative ground.
    Hope that helps,good luck
    Tom
  3. mrquickwhip
    mrquickwhip
    Thanks Tom....I really appreciate that.....I wouldn't have thought of working it out that way....thanks again....Bob in cold miserable snowing overtaxed Scotland
  4. ClayMart
    ClayMart
  5. mrquickwhip
    mrquickwhip
    Thanks claymart.....some real good info there.....Bob
  6. Rusty O'Toole
    Rusty O'Toole
    6V + ground. AMC changed to 12V - ground in 1956.
