1952-59 Ford 52 Lincoln differences
Discussion in 'Off Topic Hot Rods & Customs' started by tcoupekyle, Dec 24, 2023.
  1. tcoupekyle
    tcoupekyle
    Thinking about maybe buying a 52 Lincoln, are these cars incredibly different from the ford counterparts?
  2. nosford
    nosford
  3. tcoupekyle
    tcoupekyle
    Sure, but mechanically? Frame, suspension etc etc
  4. nosford
    nosford
    1952 was the first year of the BIG Y-Block engine, the Fords still used the flathead until 1954 and then it was a small Y-Block and nothing interchanged. The Lincoln used a Hydra Matic in 52, the Fords used a two speed Ford-o-matic. The frame was a much longer wheelbase and much heavier along with the body differences. Pretty much everything was different. I think the Hydra Matic transmission was sourced from GM , there was a fire at the GM plant sometime in the 50's and messed up the supply of transmissions. Someone who is a better historian will need to chime in on this one. Just a side note, there was a movie with Lucile Ball and Desi Arnaz from the early 50's called the long, long, trailer. In the movie they are pulling a huge (for the time) travel trailer cross country. In the beginning of the movie there was a Mercury convertible pulling the trailer but by the end of the movie it had changed to a Lincoln convertible because the flathead in the Mercury didn't have enough power to pull the heavy trailer up the Rockies so they changed cars because the Lincoln had more power and more gears in the transmission. https://en.wikipedia.org/wiki/The_Long,_Long_Trailer
  5. tcoupekyle
    tcoupekyle
    Oh wow dang ok, so maybe not a easy swap to 302 and so forth
    thanks alot
  6. Paul2748
    Paul2748
    All FORD Fordomatics were three speed up to and including 1958.
    tcoupekyle likes this.
  7. nosford
    nosford
    Okay, I know my 55 was a three speed that started in second gear when in drive but I seemed to remember my 54 239 had a two speed. BUT that was 50 years ago and I slept since then. All my other 54's I have owned were manual transmissions. I don't claim to be an expert, just old!
    56longroof, jimmy six and tcoupekyle like this.
