Hot Rods 525 GM box in a 40 ford
Discussion in 'The Hokey Ass Message Board' started by macs67, Jul 31, 2011.
  1. macs67
    macs67
    if you do how did u set it up? my 40 ford pickmup doesnt have steering with the stock fr. end my questions are
    #1 what years/doner cars are the GM 525 steering box in
    #2 what did you use for parts from the box over?
    #3 how do u like it, much bump steer?
    thanks
  2. ramrod2624
    ramrod2624
    Im putting one in my 41 right now. replaced the vega box that was there. the 525 bolts right up to the vega mount. if you don't have a vega mount they are readily available, but need to be welded in. not sure what year but I think they are pretty much the same. I needed a short shaft box to get mine to work, only because I already have the steering column installed. ill let you know about bump steer once I get it on the road. oh I would also say the 525 is probally a better way to go on the truck as I broke one of the ears off of the vega.....
  3. macs67
    macs67
    ramrod ty for responding. i was talking to the rep from drakes @ my local car show yesterday and he suggested that box and now im curious is a power steering box possible? do you have a stock front end? how do i know its a 525 when im looking?
  4. Novas, Camaros, Chevelles, and other mid-size GM use these boxes. Chassis Engineering makes a mounting plate that adapts them to stock '37-'48 car and '37-'47 pickup steering box mount. Pitman arm splines are the same as early Ford, so you can use Henry's pitman arm. The box on my '38 Ford pickup came out of a '64 Chevelle and has the original Ford pitman arm on it.
  5. macs67
    macs67
    Is this a power steering box? is it identified by a "casted in # 525?
  6. macs67
    macs67
    hey 38 ty for the reply, nice 38 there
  7. hot rod wille
    hot rod wille
    I noticed you said"short shaft box"? Who makes it? i have a Vega box on my 37 coupe,and could use one of those boxes.Don't want to redo the column,so a short 525 might just do the trick.
  8. coupe33
    coupe33
    The 525 is not power but the 605 is. They are mid 60's through 80's. Mid size GM boxes Pontiac Buick Olds.
  9. edsel
    edsel
    I found mine in an early S10 pu, plan to use it on a 55 chevy gasser.
  10. macs67
    macs67
    ty coupe33 & edsel is there any identifable marks on it i remember the 605 was casted w #'s is the 525 the same way.
    Any one have p/s on there truck?
  11. Jmountainjr
    Jmountainjr
    The GM 525 manual steering box was used by GM and others - Nova, Camero, Chevelle, late 60s - mid-80s; Jeep into early 90's. Factory made both long (about 3") and short (about 1") input shafts, as well as both fast ratio (about 4 1/2 turns) and slow ratio (about 6 1/4 turns). Also used in many industrial equipment - fork lifts, farm machinery, etc. Available many places new, used , rebuilt. I've even seen some new "off shore" copies. If you get a used one to rebuild, you can find the rebuild kits at many farm / industrial parts places for about 1/3 of the cost on the auto places.
