53-54 Chevy on Supremes
Discussion in 'Off Topic Hot Rods & Customs' started by TheOldDude, May 24, 2024.
  1. TheOldDude
    TheOldDude
    Hello!
    I'm curious if any of you are running 15" Supremes? I've got a 54 Chevy 210. I'd like to run some supremes on some wide white walls, I dig the look. Can any of let me know (that are running this set up) what backspace and offset you're running?
    Thanks!
  2. snoc653
    snoc653
    from Iowa
    You might not get a lot of response as the Mustang II front ends are Off Topic (OT) on this forum. The forum is dedicated to 65 and older and the front ends weren't out then. You could rephrase the question and leave out the type of front end, speak to track width, bolt pattern, distance from rotor/drum face to obstructions that would limit back spacing. Good luck with you search.
    TheOldDude likes this.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    I moved it to the off topic forum
    firstinsteele likes this.
  4. TheOldDude
    TheOldDude
    @snoc653
    Understood.
    Thanks for the heads up man! I guess I better read the rules a little better. My bad! Take care man! Enjoy the long weekend!
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    I moved this thread to the off topic forum. you can talk about anything here
  6. Measure current back space
    Use the measurements for the wheels you want to use and compare the measurements.
    You can use wheel manufacturer dimensions to figure out fitment
    TheOldDude and Moriarity like this.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Wait, What!? A place to talk off topic, here. :confused:
  8. Sky Six
    Sky Six
    from Arizona
    Hey, @Moriarity said it, it's good as gold. :)
