53-54 Chevy uprigths on a 51
Discussion in 'The Hokey Ass Message Board' started by kan't spell, Nov 7, 2007.
  1. I want to get my 51 Chevy a little lower in the front and I was thinking about getting a set of uprigths from a 53-54 Chevy. I have seen a few different posting about this swap and some say they will lower the car 3/4 of an inch and another said 1 1/2 inches. Has anyone done this? How much lower did you get? Do you also need the change the steering arms to the 53-54 parts?
    Thanks
  2. slamdpup
    slamdpup
    ive heard 1 1/2 aswell never did it though..i wouldnt waste the time for 3/4''
  3. What's an upright? Spindle? If it does lower it, would it be a downright?
  4. 53sled
    53sled
    from KCMO
    53-54 uprights will give you 3/4 -1", where as the drop uprights for a 53-54 on a 51 will give you almost 3"
    Rule of thumb. The upright is a separate piece on the older cars, spindles are 1 piece units (axle stub, steering arm, upright) on cars with ball joints.
    You also get to upgrade the brakes to a better drum style (bendix> huck) Get the whole assembly. I read somewhere you can use later drums and get roller wheel bearings to replace the ball bearing hubs, but I've never done it.
  5. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    If you were a bit closer to where I am at I would give my whole front suspension just to get it out of my way.
  6. rustypipes
    rustypipes
    from san jose
    I have a nice set of stock 54 uprights forsale, let me know if your interested, Phil
  7. Thanks for the info guys
    I was just looking at some of the junk in my garage. Does any one know if the uprights off a '39 would fit on my '51 Chev? They look like they should lower it between 3/4 and 1 inch. I looked and the part number for the king pins is the same, I'm just don't know if the geometry is different some how. Any Ideas?
    Rustypipes, I sent you a PM about your parts.
  8. I can't stop laughing, I tried several searches looking for this post.
    then after 65 pages I find it's by "Kan't Spell" and he has it uprigths.
    I just wanted to read the part about brakes and bearings. I just picked up a pair of uprights (torched A-arms) complete with drums.
    my 54 GMC with 50 passenger car front suspension dropped my truck 7 inches and I wanted 8 so it's perfect for my application. my 56 Olds I changed the Ball bearing for Roller bearings. does any one have an inter change for the Chevy?
    Kan't Spell you're OK
  9. I downloaded the spell check program tonight. Maybe that will help me. :D
  10. 49ratfink
    49ratfink
    www.chevsofthe40s.com has the roller wheel bearings. that's the best I can do.. I have no part numbers since I got roller bearings by going to disc brakes on my car...
