53 Ass ?????
Discussion in 'The Hokey Ass Message Board' started by Keith English, May 10, 2006.
  1. Keith English
    Keith English
    Whats up heres a ????? for you guys. How low can you put the ass of a 53 chevy with blocks and not bottom out on every little thing that you hit?
    I run a 63 impala rear with the factor 53 leafs. its open drive with a 69 chevy 3 speed
  2. JRODHOTROD
    JRODHOTROD
    from Manor, TX
    How is the ride currently? Rough? good?
  3. Keith English
    Keith English
    Its okay but I have already put 3 in blocks on it but I want more. If i hit a healthy bump it hits the bump stops witch I forgot to remove "idiot"
  4. Keith English
    Keith English
    The ride is Okay I put 3 inch blocks in because when I got It It look like somthing from the muscle car era. But I didn't cut the bump stops off "idiot"
  5. mikekillstheday
    mikekillstheday
    Cut the stops and c notch the frame. cut a semi circle and weld in a piece of steel tube cut in half.
  6. 57JoeFoMoPar
    57JoeFoMoPar
    take out a couple leafs with the blocks. that'll bring you down a littel closer to the earth. Get ready for a bumpy ride though, that's the price you pay to look cool though
  7. Custom54
    Custom54
    I have a 54 Chev, de arched the springs 2" and put in 2" blocks. My drive shaft was hitting the tunnel, and diff hiting the frame on big bimps.
    C notched the frame, made the tunnel a little bigger and now no problems, will go down another 2" this summer.
  8. JRODHOTROD
    JRODHOTROD
    from Manor, TX
    how about the steering?
  9. Big-Olaf
    Big-Olaf
    ditch the blocks, take out half of your springs, and go get the rear airbags and pump from a mid 90's Lincon mark 7 LSC then add the frame notch....:D
  10. v8spence
    v8spence
    you gotta bag that 53.....
    smoother ride and when the rough roads are the only route, you can pump it out of the weeds!
    easy conversion imho....
  11. 53sled
    53sled
    from KCMO
    any more block and you get below the scrub line, and the stock leaves are too wimpy for open drive to begin with. De-arched or posies springs would help. After we close on the new house I am going to re-work mine, I'm not real happy wih the blocks.
  12. rustypipes
    rustypipes
    from san jose
    Ditch the blocks!!, notch it and bag it. Theres no other way to go on those cars If you want it to sit right and ride right. I had my 54 lookin good on the stock stuff rode like garbage, I bagged it without the notch, and its looks good when parked and deflated not as low as I like. Im goin to put in one of the Notches from Gambino Kustoms in about a month. Designed specifically for 49-54 chevys. Checkem out he's a HAMBER too
    www.gambinokustoms.com
  13. Keith English
    Keith English
    Well the steering is okay but there is a little bump steer, someone many years ago before me has cut and heated the front coils.I put 3in dropped uprights on a freinds 54 and I still have him by a 1/2 in in the front.
  14. Keith English
    Keith English
    Iam thinking about bagging the rear but not notching it it would sit low enough for me, I am thinking a 2 link with panhard bar with the bags either over the rear or on the link bars I have heard that when you put the bags there that you get a much better ride.
  15. This is my '51 (same frame) almost as low as it'll go without a notch (before I cut the bumpstops). If you're gonna go through the work of a 4-link rear and bags, why not notch it too?? I second the recommendation of the Gambino Kustom's notch kit...I've seen it in person and on a '54...it's top notch (sorry, no pun intended).
  16. i just ripped out my leaf setup.. picking up my 4 link rear axle today, i had 2 blocks in mine with an air over leaf setup.. it went low till it hit the frame. I'd go with mikekillstheday's suggestion, very easy to do. Oh and make sure your brake lines arent running above your axle because they will be squished in no time.
  17. v8spence
    v8spence
    yeah, found that on the buick, the original lines ran directly under the upper bump stops, once bagged I crushed the lines....oops..
    new lines well outa the way now.
  18. Boones
    Boones
    from Kent, Wa
    1. Northwest HAMBers
    bagging the rear is the way to go
  19. Keith English
    Keith English
    The reason that I don't realy want to notch the rear is that if I every wanted to ever, for any reason, put the fixed suspension back in I can. and with a custom 2 link I can use the factory front leaf hangers as mounting points for the link bars. Plus I plan on leaving the front like it is because I want that Ass Dragger look.
