Technical 53 Bel Air Intake Problem
Discussion in 'Traditional Customs' started by RTi04, Aug 18, 2016.
  1. RTi04
    RTi04
    I ran into a problem after installing a firewall-mounted master cylinder - a problem that I should have seen coming, but am embarr***ed to admit I didn't. I took the air cleaner off the carb so I'd have more room to work. When I was done, I went to reinstall the air cleaner, and it won't clear the new master. It is close, but it catches the master just before reaching the carb. Does anyone know of a smaller/different shape air cleaner that I could look into? I thought about using a silicone coupler to lift it up just enough to clear, but I think that will cause it to interfere with the hood. This is on the stock motor and carb, btw. Any suggestions?
    Sent from my SM-G900W8 using Tapatalk
  2. F&J
    F&J
    I ran into same issue on a 6-cylinder 60-66 chev pickup with big booster etc.
    I don't know if it works on that car, but I used a stock GM truck aircleaner maybe a bit newer? from a wrecking yard,... that has the air cleaner on the p*** side of valve cover, and a squished looking crossover oval pipe to the carb.
    I just don't recall if it was a big truck?, but it was stock GM, and I think late 60s-very early 70s
    It had a bolted on bracket on the p*** side of head, for the aircleaner body. The part on the carb top was a short, very flat 90 degree elbow.
  3. 302GMC
    302GMC
    from Idaho
    '47 - mid '50s Chev pickup standard size oil bath. If your carb has auto. choke, check for clearance. There's also a tiny dry one made pre-war, but it isn't much more than a "look what I found" thing.
  4. RTi04
    RTi04
    Ok, great! I'll look into those! Thanks!!
  5. 325w
    325w
    Tri five six sticks it out to the left more.
    RTi04 likes this.
  6. bowtie56jw
    bowtie56jw
    this is off a 57 chevy p***enger car with a 235.
    it will be on the drivers side. KIMG0386 (1).jpg KIMG0387.jpg KIMG0388 (1).jpg KIMG0391 (1).jpg btw its for sale 75$ plus shipping
  7. 'Mo
    'Mo
    The dry-element truck air filter from a 216 is a popular choice that can still be found.
    (Seen here cleared, but black tops when stock). Check E-Bay.
