Projects 53 BelAir Front Suspension
Discussion in 'The Hokey Ass Message Board' started by 53Maureen, Jul 30, 2013.
  1. 53Maureen
    53Maureen
    Ok -- here is the first thing I want to get finished on my 53 BelAir.
    It has the stock front end with drum brakes. When I brake she pulls hard right and the steering is sloppy. I would like to not make this first item of business my last one because of budget-- so all ideas would be helpful.
    Should I repair what I have or save up to put in disc brakes with a new front end? (I know mustang II is a popular route).
    This is a cruiser for me and not a daily but I'd like her to drive solid and respond when braking.
    Thanks.
  2. ems customer service
    call ch***is engineerig i iowa great simple bolt on 53 chev front steering
  3. fastcar1953
    fastcar1953
  4. cody1958
    cody1958
    from wichita ks
    maybe your left one needs adjusted try adjusting it. I adjusted mine before I went to salina this past weekend cause it always seemed like it pulled. Now I feel like it's pretty even. I also noticed I had low tire pressure in the side it pulled to. Mine is a 51
  5. A pull can be a bad hose or an out of adjustment set of shoes.
    Hoses are under $10 at Napa and the shoes and hardware are also all cheap, wheel cylinders are about $30-$40 a shot but can also be had. You could replace everything except the drums for around $150-$200. The drums are available also but you might have to have a shop change them as the hub's not included.
    Steering box may just need to be adjusted, it probably has some wear, look over the various bushings and joints too.
  6. 53Maureen
    53Maureen
    All great stuff guys! Thank you for the tips! Keep them coming and I'll keep you updated.
  7. hobbyjp
    hobbyjp
    from socal
    You dont need disc brakes unless your running a V8 or you like to spend money. If the drums are properly adjusted and you have no leaking cylinders and youve bleed the brakes you should have no problem stopping. Last time I had a pull it was because one cylinder was leaking and the other side was doing all the work. As for the steering, jack up the front end then steer the car, you will see where the sloppy steering is coming from. alot of the time slop is in the steering connections not the box and if your running bias ply it will seem like your steering box has play. If you got the time I would rebuild the front suspension.
  8. 53Maureen
    53Maureen
    Thanks! I am running a 350 small block with an turbo 350. Sorry I didn't mention that earlier. Would you still keep the drums with a 350?
    Appreciate the steering tip
  9. Rebuild, it's a good suspension system. As far as disk brakes, I'm the original owner of a 67 RS/SS Camaro, 350 4 speed with drum brakes. Both cars are close in weight. Never needed disk. In fact "I MAY BE WRONG", but I think the 350 and 235 weigh close to the same.
  10. Johnnymurt69
    Johnnymurt69
    Man my 53 pulled like a bear to the right when I first got it home. I figured major issue. All it needed was adjusting . Now she stops nice. I got lucky, but thats where I would start.
  11. 53Maureen
    53Maureen
    Good stuff! Thanks!!!
  12. Lone Star Mopar
    Lone Star Mopar
    All you need is a brake s****, 10 minutes worth of adjustment and you'll be stopping just fine. Nothing wrong with discs and M2 if that's your trip, but it's Damn sure not necessary. Ps a s**** cost less than 10$ at any auto parts place.
  13. Dutch54
    Dutch54
    If you decide to go disc, I've got a 54 cross member set up for disc brakes in the cl***ifieds. I'd be willing to part out if your interested.
  14. Another thought, my 49 shoebox used to do that and the problem was one wheel cylinder was gummed up. Replaced the offending part, problem gone.
  15. 53Maureen
    53Maureen
    Yeah? It's called a "brake s****"? I trust you... but wanting to make sure when I go to the parts store so they don't look at me weird. Ha.
  16. 53Maureen
    53Maureen
    I guess I just need to get in there and see what it all looks like. **Weekend project set!**
  17. sweeden
    sweeden
