Projects 53 Business Coupe Build
Discussion in 'The Hokey Ass Message Board' started by 53chevtrev, Nov 26, 2011.
  1. gotit
    gotit
    did you raise the front of the frame?
    Edit: I see that you did. Looks good
  2. 53chevtrev
    53chevtrev
    from Langley BC
    i raised the front of the frame up 1.5" to gain clearance between my oil pan and my MII crossmember and clearance from ground as i went so low.
  3. 53chevtrev
    53chevtrev
    from Langley BC
    More progress on the floor sheetmetal. Got my driveshaft tunnel rolled by a guy for $20, I wanted a 7" radius and he was able to do a 8" one that wasn't very good. After a bit of working, i got it to a radius i was happy with and it turned out great in the end.
    Fitted the new inner fenders.
    Fabricated new mounts for the aluminum tank I built in the summer for the car.
    All bolted up, ready for trunk floor.
    Decided to go with a one piece floor to save on the welding. This is my first time using a bead roller and i am happy with the end result. Thanks Schaefer for helping me out!
    Folded some edges onto it.
    Fits perfect!
    Zed section fitted, ready for trunk floor install.
    Floor installed, very happy with how it turned out!
    Make up pieces for back of my wheel tubs.
    Got the driver side tub finished yesterday.
    Decided to throw the front fenders and radiator support on. I had to cut a lot of the inner fenders out for my upper control arms and my tires hit when the car is fully aired out. Will need to fabricate new ones.
    rytang likes this.
  4. Great build. Subscribed, 53' Club Coupe in Oklahoma
  5. 53chevtrev
    53chevtrev
    from Langley BC
    I have decided the roof needed to be chopped, with schaefer on here, we have been planning and researching for a few weeks now. Yesterday we started prepping for cutting the roof and everything was going so smoothly we went ahead and cut the roof off.
    Inner bracing and seat back wall
    Back window reinforced
    Top of doors cut off
    B pillars marked
    B pillars removed
    Cutting out the corners of the rear windows
    Cutting around back window
    Marking out A pillars. I am cutting 2.75" out of the A pillars and 3" out of the rear of the roof.
    No going back now
    Roof sitting back on the car
    Had to roll the car outside to have a good look at it from further back. I am really happy with how the roof sits on the car at this point in time. Schaefer and I decided to not go crazy as it is a coupe and wanted to keep the rear side windows a decent size. Cut too much and they get small and funny looking.
    Put some tape over the b pillars to get an idea of how they will sit. I am going to pitch them forward a bit, make it flow a bit more.
    This is all the progress we got in yesterday. Decided to leave it sitting for a bit and i will have a look this week to make sure im happy with the height and lines of the new roof. Next weekend i will start welding everything up.
    cretin likes this.
  6. schaefer
    schaefer
    We made a lot of progress yesterday, everything went nice and smooth. I had great time, can't wait to see it all back in one piece!
  7. jwl53
    jwl53
    from So cal
    Looks awesome dude. Very nice work. Building 53 ht myself. Keep the pics coming. Very inspirational.
  8. deeddude
    deeddude
    Awesome Work. Looks Good, keep the updates coming.
  9. DMacias
    DMacias
    from So Cal
  10. yetiskustoms
    yetiskustoms
    Great looking build so far, great hab work. Looks like a pretty good car to start with too. Keep us posted
  11. 53chevtrev
    53chevtrev
    from Langley BC
    Loads of progress today. Big thanks to Schaefer once again for all the help!
    P***enger side b-pillar shortened and fitted along with the top of the door.
    Driver side door and b-pillar fitted.
    Rolled the car outside after we cut the back window loose to take a look at where we should put the window.
    Started to tack the roof back to the window. Was getting tired at this point so we called it a day. Need to start fabricating the fill pieces for the b-pillars and the bottom corner of the side windows.
    rytang likes this.
  12. Hot Rod Chris
    Hot Rod Chris
    Holy **** how did I miss this!!!! This is ****en awesome!!!! Love it!!
  13. 53chevtrev
    53chevtrev
    from Langley BC
    Thanks Chris!
  14. DoubleJ52
    DoubleJ52
    from Belton, MO
    This is a great project, absolutely beautiful!
  15. joe little
    joe little
    from UK
    Man this is way cool, your doing some very nice work here.
    Joe
  16. elvi411
    elvi411
    Nice work! The chop looks good.
  17. Hot Rod Chris
    Hot Rod Chris
    No problem bro, hey quick question how are u gona attach the wheel tubs to the inner fenders. I was planning on doin a similar treatment to my wheel tubs but was wonder how to attach them to the quarters and keep the water out. Thanks
    rytang likes this.
  18. You're doing an awesome job,man.
    I love the blue, are you planning on keeping it?
  19. deeddude
    deeddude
    Like everyone else stated, this build is awesome. The metal work looks outstanding. Keep us posted.
  20. JJK
    JJK
    Well done sir.....
  21. shoebox50
    shoebox50
    Very nice work!!
  22. rockable
    rockable
    That is going to be a killer!
  23. CheatersPete
    CheatersPete
  24. 53chevtrev
    53chevtrev
    from Langley BC
    I will be putting a filler piece in from the inside of the fender up to the 90 degree lip of the wheel tub. I haven't put them in yet as they were going to be very awkward to do with the car on the ch***is and rear end. Once I have finished the chop, the body is getting put on a rotisserie, sandblasting the whole thing then i will finish the underside and wheel tubs where access to them will be much easier.
  25. mrconcdid
    mrconcdid
    from Florida
    Great job, looks outstanding
    keep at it, I looking forward to see how this all turn out.
    Godspeed
    MrC.
  26. Hot Rod Chris
    Hot Rod Chris
    Aaaaah I see!!! Lucky... Im gona have to do mine the hard way as I dont have access to a rotisserie...
    Yay me :rolleyes:
    Keep up the good work. I wana see this one finished.
  27. fastcar1953
    fastcar1953
    subscribed, great build. lotsa ideas
  28. Awesome work
  29. xmb63
    xmb63
    from pittsburgh
    Looking good.
  30. 53chevtrev
    53chevtrev
    from Langley BC
    Schaefer and myself got busy on building the fill pieces for the B-pillars and re-fitting the rear window corners.
    New window radius versus the original window corner for the drivers side.
    Radius fitted nicely. We then re-fitted the factory body line termination to match the new radius.
    All fitted. Happy with how the rear window looks now. One issue with the body lines lining up at the top of the door...
    Adjusted the body lines to line up at the top of the door.
    Began the drivers side B-pillar. Because we slanted the pillars forward and had to open the corner of the top of the door, the factory body line got all messed up. Used the piece we cut out of the door at the A-pillar to patch a piece in to make it work.
    Another shot as we were fitting a filler piece.
    About to cut and reduce the radius for the drivers side.
    Rough fit of the corner, now onto reinstalling the body line termination.
    Driver side window all re-fitted. Very happy with how the second side turned out.
    Its always good to get a look from far away to see how the car will sit and flow. We put the hood and trunk back on roughly just to see it as a whole once again. So stoked on how this car is looking now. Im glad I did not go crazy on the chop, I think this is the perfect amount for this business coupe.
    Another angle, loving it! Next week I will finish up welding and smoothing the sides out in preparation for starting work on the rear window and sail panels.
    rytang and cretin like this.
