Technical '53 Chev wiring help
Discussion in 'The Hokey Ass Message Board' started by cavman, Mar 15, 2025.
  1. cavman
    cavman
    I have searched the world over and can't seem to find... Steering column wiring diagram for the turn signals and horn on my 53 sedan. Does anyone have a direction they could point me in, or possibly a diagram they would share? Stock column, factory wires.
    TIA
  2. squirrel
    cavman and pprather like this.
  3. squirrel
    another version on the internets, click to expand it
    cavman and 41 GMC K-18 like this.
  4. Onemansjunk
    Onemansjunk
    from Modesto,CA
    IMG_2394.jpeg Hope this helps
    cavman likes this.
  5. cavman
    cavman
    This was a great help.. . Thanks
  6. cavman
    cavman
  7. cavman
    cavman
    It turns out after trying to match old wires to new, and testing for continuity, one wire leading from the turn signal switch in the column had over time became damaged inside the jacket. I pulled the whole thing out and testes the switch and found out it was bad too. Luckily, I just happened to have another complete column I unsoldered the old wires from that switch and attached new color matching wires. the trick was to feed the bunch down the column and out the tiny hole while in the car. Thanks for the quick and helpful replies. I save copies of everything
    Johnny Gee likes this.
  8. Onemansjunk
    Onemansjunk
    from Modesto,CA
    Hello, Caveman. I soldered new wires to my switch as well. 15 years ago. That is why I couldn’t give you wire colors on my bar stool diagram. I salvaged wires from a 1988 colony park station wagon. The front turn signals are separated from the back turn signals by the switch itself.
    cavman likes this.
  9. 302GMC
    302GMC
    from Idaho
    '53-'54 turn switches can be repaired. Bend the tabs & SLOWLY pull the thing apart. You'll find a tiny contact spring broken or it's full of dirt & gummy stuff.
    The spring in a Bic lighter is the right size, just cut to fit. Light lube & replace.
    BJR, RMR&C and squirrel like this.
  10. 325w
    325w
    Tie a string to the lower wires. Pull switch out. Reverse pull string back down. Magical things happen the wires are back in place. In the factory we had a plastic string to do this. Have never found a source for it outside the factory.
    cavman likes this.
  11. squirrel
    I use baling wire, but then I'm a glutton for punishment.
    cavman likes this.
