Projects 53 Chevy Bel Air "Cleetus" mild custom daily driver
Discussion in 'Traditional Customs' started by The Chevy Pope, Sep 15, 2023.
  1. twenty8
    twenty8
    The self-drilling screw ends are a nice touch. How many times have you caught your arm on them?:D:rolleyes:
  2. Actually haven't because of where they are lol. Don't have a welder so tunnel and floor patches were self tappers and seam sealer for now. Only reason I was able to perform my "amazing" welds on the crossmember was because I could unbolt it and take it to work lol
  3. In the process of making the crossmember work with a modern mount I did discover the source of the popping going between drive and reverse. Apparently with the quarter inch plate I was using as an adapter the bolts holding it to the transmission didn't have enough bite to stay torqued and had backed off a couple turns. Basically I was hearing the plate slide up and down the bolts
    Okie Pete likes this.
  4. tomcat11
    tomcat11
    Ouch..;)
    twenty8 likes this.
  5. patsurf
    patsurf
    ever thought of becoming a professional photographer?....prob shouldn't...
  6. Hey now. Yelp even gave me an award for my picture taking ability lol. Actually am skilled at photography. Even blue ribboned at the Missouri state fair in photography as a kid for black and white pictures I took of a turn of the century mini mansion they were going to tear down to build the current O'Reilly. But not much room under my car....even on ramps lol
    Outback and Okie Pete like this.
  7. Thinking about trying a flux core welder off Amazon. Hobo freight never seems to have them in stock. And pawn shops want goofy amounts for cheap welders. At the very least I could use it to tack my exhaust together to remove and weld up at work. At a point where some of the welding needs to be done on car
    Tim and Okie Pete like this.
  8. And a current small side project from the cheapass file lol. Found a box of stainless wood screws in an old toolbox of my grandpa's in the shed. Some of my garnish moulding screws were missing and the ones left were rough looking. Decided to replace them with the wood screws. Similar thread and size and easy enough to cut down for the short ones. But the larger flat heads looked off. Took one to work and spent a few seconds on a bench grinder to see if feasible to reshape them. While I rushed this one and it's uneven it shows it is. Ill dig out my own bench grinder this weekend and get to reshaping. Then I'll sand and polish IMG_20241022_215201168.jpg
  9. Guess I get to repeat my change flex plate with pulling engine or transmission truck lol. Finally figured out the reman starter had a defective starter drive and damaged the good used flex plate I put in. I'm going to fill out a work order on this one
  10. And here we are for this weekend. Gotta look up book time to remove a trans and replace flex plate before trans reinstall on a 76 C10 tomorrow. Guessing book is 2-3 for removal and 2-3 to reinstall. So I should get a couple hundred plus parts and materials for my efforts. Just ready for the starter to work correctly again lol IMG_20241024_195341054.jpg
  11. Got the starter warranteed tonight. Had to get a bit pushy because it was a machining flaw and not a mechanical one. They still insisted on testing it. Which It did pass.... though gear had a delay in extending. Anyway I noticed when they got me the replacement that the mounting holes weren't quite in the same spots. Not far off enough to indicate wrong application but enough you could see the difference without measuring. Get home and throw it on. There was a tiny bit of grind noise due to the damage from the other starter but it spun over much smoother. I'll get the new flex plate on tomorrow and should be good
    Baumi and Okie Pete like this.
  12. Got the Amazon welder tonight. Practiced on a couple of scrap pieces and aside from needing to figure out the heat settings on it it will for a fact stick two pieces of metal together. I guess next I'll order a few prebent mandrel bends so I can stick some metal together and ditch the flex pipe IMG_20241026_212908846.jpg
  13. Honestly half tempted to just angle cut and weld some pipe lol. I have plenty of exhaust pipe. Would save close to $100 and I could always replace with bent pipe later on. And this won't exactly be a drag car so optimal exhaust flow really isn't important lol
  14. Okie Pete
    Okie Pete
    Maybe you could gather up some old exhaust pipe at a muffler shop and harvest the bends you need . A friend of mine had a motorcycle shop . He let me gather up pieces with bends for a project I once did .
    Tim likes this.
  15. Tim
    Tim
    from KCMO
    Can also get cheap crinkle bends at the parts store. Nobody’s gonna be looking under it anyhow
  16. Problem with crunch and bend is it doesn't turn tight enough. Otherwise I would have already grabbed some. I think regardless on the driver side Im going to do the angle cut and weld thing. Such a short section plus it's only like a 30° bend.
    Okie Pete and Tim like this.
  17. Here's what I had to do to clear the steering box lol. One thing that makes this part of the job a pain is I'm tying directly to lakes pipes as sole exhaust. If it just tied into undercarriage exhaust it'd be simpler. But in the longer run it'll make stuff easier down the road. Basically I have to contort it tight around the frame while curving it tight to the actual pipes. On a car not exactly known for exhaust clearance. Lol. As it is I'm cheating a hair and doing 1.75" pipe from the passenger manifold to the first bend to gain a lil breathing room for the starter. FB_IMG_1730087774998.jpg FB_IMG_1730087768379.jpg
    Tim, TrailerTrashToo and Okie Pete like this.
  18. Ok I talked myself out of hackery on the passenger side lol. Am sticking with that angle cut and weld on the driver side since it's such a short section and such a mild bend
    Tim likes this.
  19. Tim
    Tim
    from KCMO
    It’s just metal you havnt got to nail it the first time. I would suggest tack and try before you bother making it solid though
    The Chevy Pope likes this.
  20. Got the driver side done. Already sounds better despite what my crappy phone audio says lol. Lot more base to it. Still gotta start on the passenger side
    Lone Star Mopar, Tim and snoc653 like this.
  21. May just end up running these grills in the rear. Screenshot_20241103-103312.png
  22. And finished up welding a squiggly pipe for the passenger side. Luckily it didn't have to be as squiggly as the driver side lol Messenger_creation_A2294E02-4907-4868-94D4-E69CDD0D4EB0.jpg Messenger_creation_D0F4A138-709A-4020-9E3C-2A572EEF0630.jpg
  23. Clydesdale
    Clydesdale
    5FC3C002-6200-4D74-8D24-CA21FB4C56BC.jpeg 3C9A44ED-0950-478D-BFE8-A25FF7C20F48.jpeg Reminds me of the monstrosities that the previous owner had thrown at my ‘51 and my slightly better replacements lol
  24. I made a point to use all new pipe lol
  25. Okie Pete and Tim like this.
  26. Tim
    Tim
    from KCMO
    Car exhaust on video is nearly impossible to get right on a phone camera and if you did get it we are all listening to it on phone speakers so it doesn’t matter lol
    congrats on progress
  27. Yeah my phone is progressively crashing slowly. I noticed the clip of the passenger side was lower quality than the earlier one of the drivers side lol
  28. And I'm finally getting the hang of the Amazon welder lol. Took me like 15 minutes to weld everything up. And that included filling a quarter inch gap on one side of the pipe
  29. So curse of the seasons when it comes to hot rods. Was real focused on putting together the heater while it was still cold. Got as far as finding a potential heater core. Then it got warm. And I went to other stuff completely forgetting the heater lol. Well now it's cold again. This time I for sure have settled on a heater core. This one actually takes advantage of the majority of usable area while still likely being able to fit in the slot(have to order it to actually test fit ....not in stock). And on top of that is less than a third of the cost of the Dodge one I was planning last winter. This one is for a 69 Camaro without ac. Oddly the AC heater core is bigger on those cars.
  30. patsurf
    patsurf
    c
    cuz those camaros were already hot!
