Technical 53 Chevy trim code doesn't match?
Discussion in 'The Hokey Ass Message Board' started by Cam332, Sep 29, 2024.
  1. Cam332
    Cam332
    Any help? Got what looks to be a trim code of 204 or 5. However all information I have found no trim code in 53 under like 240 doesn't exist. Body tag for reference.
    The only trim code for 1011w's was 304-307
    My trim code clearly has a 2 to start
  2. squirrel
    I can't read that tag, although it might say 245. If it were mine, I'd patiently soak it with some lacquer thinner or paint stripper, and get the paint off it...they were originally bare unpainted aluminum. Since it's aluminum, you have to be real careful not to mangle it with your cleaning process. I would NOT try to remove the tag, or mess with the rivets at all.
    here's my list of 53 Chevy trim codes...hope it helps
    jaracer, lothiandon1940 and snoc653 like this.
  3. Cam332
    Cam332
    I appreciate that. I don't intend to tamper with the tag at all, besides trying to soak it.
    Now that I see the numbers again it's possible it's a 6 or 8
  4. snoc653
    snoc653
    from Iowa
    Looking at the pic it looks like 254 to me. Jim’s suggestion sounds good. Tape around it and try not to mess up the rest of the paint. You can also try laying a blank piece of paper over it and using a pencil or a piece of chalk to lift the numbers by lightly rubbing over them.
    lothiandon1940 likes this.
  5. Mr48chev
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    full size pic. when posting pics always select "full image"
  7. Nacifan
    Nacifan
    Looks like your Aluminum Trim tag has been sprayed with undercoating. Thinner, Acetone and even Rubbing Alcohol
    should take it off
  8. squirrel
    and we can crop it and it shows up even bigger....
    lothiandon1940 and Moriarity like this.
  9. gene-koning
    gene-koning
    Why does a trim code matter? Are you restoring the car back to original?
    Match the trim to what the outside body color will end up, and be done with it.
    lothiandon1940 and squirrel like this.
  10. squirrel
    Some people think facts are interesting, Gene. Not everyone does
  11. ALLDONE
    ALLDONE
    I found this to help some times, look at the paint code,and see what matches,,,. it looks like the 24?on the trim...
  12. ALLDONE
    ALLDONE
    my 53 in the garage is 243... paint 509...
