Projects '53 Chevy truck - My crazy project
Discussion in 'The Hokey Ass Message Board' started by orula, Mar 8, 2011.
  1. n847
    n847
    I love this build! Keep up the work...This truck is amazing...love the white chasis...love the 3 window...It sounds like you have made your mind up on the white body, but your from italy, why not british racing green (ferrari green)? I love that color and it would look bad ass witht the white!
  2. skoh73
    skoh73
    Just found this today- gorgeous work! Subscribed!
  3. ...doc...
    ...doc...
    from Houston
    Wow, I just found this build thread too,...unbelievable work!
    I need to do a rebuild on my Orange 53, but my work is no where near that clean.
    Looking forward to the updates!
  4. orula
    orula
    All these compliments make me really happy :eek:.
    Many thanks to all [​IMG] [​IMG] [​IMG]
  5. 55Hydramatic
    55Hydramatic
    That would look cool green with a white chassis and engine compartment. It would definately stand out!
  6. orula
    orula
    Not bad the idea of green but I think I have already decided for the white :). Thanks 55Hydramatic
  7. SOCAL PETE
    SOCAL PETE
    from Ramona CA
    Amazing build. Very impressed with your craftmanship.
  8. orula
    orula
    Many many thanks, I am truly honored that you appreciate my humble work :)
  9. man I'm jealous. I wish I could do such good work. Can't wait to see the finnished product.
  10. RatPin
    RatPin
    $60k? Did I read that right??
  11. YUP!
    Beautiful truck!!!!!!!!!!!!!!!!
  12. -Brent-
    -Brent-
    Great job. I really like how clean and organize your frame is. It looks better than factory.
  13. piero
    piero
    Great...great job...well done...
  14. SOCAL PETE
    SOCAL PETE
    from Ramona CA
    Having lived in Naples back in the late 70's...I can really appreciate what your doing there. If it were a alfa ...sure no big deal. But a Chevy! You really can not run down to the local Napa or junkyard for parts.
  15. HotRod60F100
    HotRod60F100
    Wow,talk about every nut and bolt being redone or new on that machine. great build so far man!
  16. orula
    orula
    Hi RatPin, yes, you read that right :).
    I bought this truck for $ 25000 including transport costs to Italy.
    Then I started work shown in my thread. Just to give an example, in the next few days I have to order the new Bedside. They cost $320 each but for them to get to my house the cost becomes $1.670 for both.
    The same goes for the rest. For paint and upholstery takes about $8.000.
    As you can see $ 60.000 is not a sum impossible to achieve, but easy to overcome:)
  17. 65standard
    65standard
    1. COE's (Cab Over Engine)
    One question, how thick were the plates you used to box the front part of the frame? 1/8" or 3/16"?
  18. 56 Frame Dragger
    56 Frame Dragger
    WOW!!!!!! Your truck is BEAUTIFUL what a clean job you've done. Can't wait to to see it when your all done. Keep up the GREAT work and best of luck to you.
    Ronnie
  19. killbilly
    killbilly
    Orula,I have been following your build for awhile,it is going to be an awesome truck! It is amazing what you've been able to accomplish being where you are.Great job!:cool:
  20. orula
    orula
    Hi 65Standard, the plates are 3/16" that came with the Heidts front crossmember.
  21. orula
    orula
    Many thanks KillBilly, thanks also to 56 Frame Dragger.
    I'm doing my best and I hope to finish next year.
    Many thanks to all. [​IMG]
  22. 65standard
    65standard
    Thanks. I will be getting the front cross member from Heids Hotrods too, they are local to my area. I just needed to know the plate size because I will be boxing my entire frame.
    I am also interesting in your steering setup. Mustang rack with stock column? Like to see how you route this.
  23. orula
    orula
    No, I think to install a Flaming River or Ididit or CCP column with column shift. Making the frame boxing is a great job. Thanks
  24. pottsie454
    pottsie454
    Amazing work. Hard to believe this is just a hobby of yours??
  25. orula
    orula
    Thanks Pottsie, is just a hobby for me and if I can work well is because I like things done very well and I am committed
    to get the best result. [​IMG]
  26. 65standard
    65standard
    Orula, the mustang II spindles you're using, are they standard height or 2" drop spindles?
  27. orula
    orula
    Hi, they are 2" drop splindes :).
  28. 65standard
    65standard
    Orula, are you going to weld up or plug up those unused holes in the toe board. Mainly the floor starter hole, the clutch rod hole, the parking pedal hole, and the throttle linkage hole?
    I will be welding up all of those holes on my '53. I am only keeping the brake pedal hole and will make a new hole for the throttle cable once I figure out what I am doing for that setup.
  29. Nice truck, gotta scare the snot out of Fiats
  30. hotrod 49
    hotrod 49
    Very, Very Cool!!
