1952-59 Ford 53 Customline progress
Discussion in 'Off Topic Hot Rods & Customs' started by whatdatruck83, Dec 31, 2013.
  1. whatdatruck83
    whatdatruck83
    from Roanoke Va
    Ok so I got my Aerostar springs on, 3 inch blocks on the back and new shocks all the way around. 12 volt harness from rebel wire, T5 adapters on order as well as a larger sway bar and a 9 inch coming soon. Are there any other cool tricks out there while I have this thing apart that I should look into?
  2. leadsledjim
    leadsledjim
    from Iowa
    How about a Duel Master cylinder for your Brakes. A Disk Brake kit for front also could be done. And then there is Power Brakes.
    You Could add a Power Steering Box by Borgeson. Its a bolt on with only changes to Steering Shaft and fab up a bracket & PS pump.
    Maybe Air conditioning for those hot Days.
    Always something to do. It never seems to end.
  3. frank dog
    frank dog
  4. demonspeed
    demonspeed
    Whatdatruck- what kind of larger sway bar did you get and where did you get it?
  5. whatdatruck83
    whatdatruck83
    from Roanoke Va
  6. whatdatruck83
    whatdatruck83
    from Roanoke Va
    Frankdog I see on the video to use one for a 67 Mustang does it matter what motor?
  7. whatdatruck83
    whatdatruck83
    from Roanoke Va
    And where'd the brake switch go?
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    There are two ways to tackle the switch issue,one is to install a "T" fitting in the new line you added on the other is to fab up a bracket under the dash and use a GM style adjustable switch which is a better alternative if you have installed a new 12 volt wiring harness,there are pictures of this in our archives.
  9. frank dog
    frank dog
    There is 3 parts to those videos. The guy mentions all the parts you need.
    I just asked for a 67 Mustang with a 289. For the brake switch I put a tee fitting inline with the front brake line out of the master cylinder.
  10. JeffB2
    JeffB2
    from Phoenix,AZ
    What does matter is the master cylinder part number in 1967, the Mustangs used both drum/drum and drum/disc brakes if you match them correctly you will not need a prop valve and also there were power and non-power brake options.The video was for a drum/drum non power application.
  11. HankHearst
    HankHearst
    I used a drum/drum dual non power bowl from a 68 Mustang and used a pressure switch for the brake lights. Works great, the only thing I had to change was the push rod, I believe it wasn't long enough. I got mine from a local cl***ic mustang spe******t but you can get it from here. I also upgraded to a jamco sway bar since my old one snapped. I wish jamco would make a rear sway bar for our cars! Looks like they skipped '52-53!
  12. whatdatruck83
    whatdatruck83
    from Roanoke Va
    Hank what switch did you use
  13. frank dog
    frank dog
    For brake light switch( autozone parts are garbage,get NAPA) Ask for a 65 Ford F100 truck(240 6 cyl) with drums.
    You'll probably have a hard time finding a tee that has the thread to screw in the brake switch.
    I modified a 3/16 brake line br*** tee. On the side I drilled open to tap a NPT 1/8-27 thread and that worked out as my inline tee. That tap comes in almost every tap and die set.
  14. JeffB2
    JeffB2
    from Phoenix,AZ
    About the brake "tee" guess who has a better selection in br*** fittings than most parts houses? Ace Hardware! Got all mine for the dual master upgrade there.
  15. HankHearst
    HankHearst
    whatdatruck I used this
    [​IMG][/URL][/IMG]
