Technical 53 DODGE FRONT SUSPENSION
Discussion in 'The Hokey Ass Message Board' started by 36panelman, Feb 15, 2022.
  1. bgthegreat
    bgthegreat
    Thank you for the tip. For the guy that posted about the lug nuts, I got 4 drums for the driver side. Now all the lugs work the right way.
    COCONUTS likes this.
  2. rusty1
    rusty1
    try Fatman.com
  3. gene-koning
    gene-koning
    If your frame is not savable, I can off a few suggestions. The adventure you are about to undertake is not an easy road. You are much farther ahead if you can replace the rusty sections of your original frame, but if it is rusted past the point of a safe repair, PM me here. The info I have will be off topic for this board. Gene
  4. slim39
    slim39
    from pa
    Eaton Spring in Harrisburg Pennsylvania has original springs for early Mopors that they can dee arch for you. I have had them do it for me. I got original springs for 39 ply and 3 inch lowering and they made me longer U bolts to fit. Good luck have fun Slim 39
  5. slim39
    slim39
    from pa
    Lowering blocks
  6. goldmountain
    goldmountain
    Look at the '53 Coop build currently being done by irishjr. It is a Studebaker but the suspension upgrades are impressive.
  7. sunbeam
    sunbeam
    Put a floor jack under the outer end of the lower control arm jack it up enough to get the weight off the tire. Grap the tire and shake check for loose parts the jack under the control arm stops the spring from preloading the parts.
