53 F100 4-link/rear suspension opinion needed
Discussion in 'The Hokey Ass Message Board' started by sideshow01, Jan 19, 2006.
  1. sideshow01
    sideshow01
    from Dirty Jerz
    Hey guys,
    We're about ready to tackle the rear suspension on this 53 F100. It's running a camaro front clip. It'll be bagged, so I'm trying to decide the type of rear suspension to use. I'm torn between the 4 link from suicidedoors http://suicidedoors.com/Triangulated4-Link.php, and a cantilevered setup from candospecialties.com https://candospecialties.com/Mercha...Product_Code=CD-4LKWELDCANTI&Category_Code=41. I guess they're 6 of one, half dozen of the other, ones foreward, ones backward??? I like the cando setup, cuz it's a little more trick, but also like the simplicity of the thornbecke 4 link...b does anyone had any thoughts to help me decide. I'm thinking the cantileverd setup might fuck up my exhaust???
    Thanks
    -B
      13.5 KB
  2. Larry T
    Larry T
    Simple is good. Things get complicated enough without trying to make them that way.
  3. dodgerodder
    dodgerodder
    As far as the 4-link goes, a triangulated 4-link would be a great way to go. I'm not bashing CanDo's product, but a reversed 4-link of any type is a horrible way to setup a suspension. Without getting into a novel about why, go to this link, and scroll to the bottom of the page. It explains the many downsides to a reversed 4-link setup:http://www.ridetech.com/techarticles/air4linktechinfo.asp
    I have used Jason at Suicidedoors.com for many link setups. His quality is always top-notch, with very fair pricing. He will build the link bars to any length that you need.
    For your situation I would just run a pair of Firestone F9000 Sleeve bags over or behind the axle. The give nice lift(approx 8.5"), and ride nice in the rear of a light vehicle. The double convoluted bags, like a 2500 or 2600 tend to be bouncy in the rear of a light vehicle.
    The only reason guys run cantilever setups, or mount the bags on the link bars is to get crazy amounts of lift, needed to untuck huge-diameter wheels. But these wouldn't be needed things for a hotrod.
    Heres a couple pics of the rear of my a sedan. Its bagged, with a 3-link from Suicidedoors, and F9000 bags like I told you about above. One pic dumped, the second at ride height. The will give you an idea of what the bags look like. Hope this helps a little Dan
