Projects 53 Ford Emergency Brake Question.
Discussion in 'The Hokey Ass Message Board' started by Chaz, Mar 26, 2016.
  1. Chaz
    Chaz
    These two springs were in a box carefully labeled "Emergency Brake Parts" Since there are two, I imagine one is right, and one is left. Anyone got a picture of where they go?
  2. HOTRODPRIMER
    HOTRODPRIMER
    Chaz,they lool like the springs used on the '52-'54 Ford emergency brakes.
    hope this diagram helps. HRP
  3. Chaz
    Chaz
    No, I've figured out everthing INSIDE the drum. These definitely go outside the drum ***embly somewhere., but damned if I know where. They're about 5 inches long.
  4. dirty old man
    dirty old man
    Last '52-54 Ford I was under was in '62, but I seem to recall a spring between lever under car moved by the cable from handle inside car, and moving a cable routed to an equalizer bar, separated, and transmitted to brake shoes.
    Somewhere in all that was a spring to retract whole shebang when parking brake handle was lowered. I just can't quite get enough recollection to pull it outta my memory.
    Anyhow, might that be the spring you show?
  5. paleot
    paleot
    from louisiana
    Just went and looked under my 53, no springs any where on the cables from fire wall to rear end. May be something under the dash I did not have my keys with me to look there.
  6. No pic, but Ford used to install springs like that on some cars (and trucks) between the cables and some point on the ch***is or rear axle to keep the cables 'tucked up' and from flopping around. Theory being that without the springs, the cable could hang too low and catch on something. You didn't always find them, so I don't know if Ford only installed them on some cars or if they fell off or were removed later.
  7. dirty old man
    dirty old man
    I think you have nailed it CS, similar to my recollection, except I was" b***ackards" as to purpose and direction of spring's pull.
  8. HOTRODPRIMER
    HOTRODPRIMER
    This diagram is from the 52-54 Ford shop manual and there are brackets attached to the emergency brake cables and the frame. HRP
  9. HOTRODPRIMER
    HOTRODPRIMER
    Chuck,you might try asking members this over on the '54 Ford Club of America forum,you are a member and we have several tech guys that know all about the originally cars and odd parts. HRP
  10. HOTRODPRIMER
    HOTRODPRIMER
    Haven't heard anything from the Strange Days Quartet in a while, did you ever get the brake problem fixed?
    You guys are still working on the wagon,right? HRP
  11. Chaz
    Chaz
    Yeah Danny, We're still on it! Kinda uninteresting work right now. We do have the brakes solved, and are now struggling with engine pulleys to get the alternator and power steering belts to align. Parts are ordered and we'll post again on Sunday. (hope everything aligns this time) Engine and ****** are almost ready to drop in.
  12. jimmy six
    jimmy six
    My 56 has them on the cable near the rear end. I saw the yesterday when I had the rear wheel/tires off. Did really look where the mounted but I think they are there to keep the cables from flopping around when the E brake is not applied.
