53 ford engine swap 302
Discussion in 'The Hokey Ass Message Board' started by Kegger, Feb 17, 2008.
  1. Kegger
    Kegger
    ugh! time to put 302 in 53, does not want to fit due to front oil sump-pan, believe pan and engine are out of 70s mustang. Any help out there would be very appreciated
  2. Squablow
    Squablow
    You'd have to look into it, but I've always heard that the oil pan/pickup from an early Bronco is what you need to fit one into a shoebox.
  3. igby
    igby
    doing same on my 50 ford convertable just bought bronco reverse pan and pump from ford.:D drops right into my car. 250.00 from ford or find old bronco.
  4. bulletproof1
    bulletproof1
    from tulsa okla
    my 302 has a rear sump oil pan .the motor came out of a mid 80s van..the first 302 came out a mustang.it also had a rear sump.the crossmemeber was cut out when the flathead came out.not a pretty job.before i put the new motor in i boxed the crossmember in. also had to cut a hole for the oil filter ...
  5. solo_909
    solo_909
    My 86 mustang 302 has the double hump and fits perfect in my merc with no problems
  6. okiedokie
    okiedokie
    from Ok
    There ya go, late 80's, early 90's mustang 302 pan. I used one in my 53 f100 and welded in a drain back tube to allow use of only the rear drain plug. It has two, one in each sump. but it fits as good as Bronco pan.
  7. Paul2748
    Paul2748
    Vehicles withe rear sump pans (302) - Sorry, don't have years
    Bronco
    Mustang
    Fairmont
    LTD II
    Crown Victorias
    You need the longer main cap bolt and the pickup tube for the pan used.
  8. AnimalAin
    AnimalAin
    Your local salvage yard guy should know about this..... or your local Ford parts man. Of course, used stuff is cheaper, but it isn't too expensive new from the dealer.
  9. rstanberry
    rstanberry
    from terrell tx
    Bought a rear sump from Ford Racing, still has a bump in the front for the pump but has a rear oil pickup. about $250 I think. Check Ford Racing online site
  10. curtiswyant
    curtiswyant
    Summit has a fox body mustang oil pan conversion kit. It was about $100 with pickup tube etc.
  11. tewkes
    tewkes
  12. Mudslinger
    Mudslinger
    Theres a special bolt on the 302 rear sump that has a nut on it I believe.
    You mount the rear pickup tube on the nut thats on the main bolt.
    Or Im talking out of my *** :)
  13. Crankhole
    Crankhole
    COOTER's got a rear sump pan for a 302 for sale in the cl***ifieds right now.:D
  14. Kenneth willette
    Kenneth willette
    What year is your merc
