53 Ford rear end need donor info
Discussion in 'The Hokey Ass Message Board' started by Kegger, Aug 1, 2011.
  1. Kegger
    Kegger
    Ok, my 53 customline still runs stock rear end, this was a flat v8 and is now a mild built 302 w/c4. At 70mph its turning 4000 and pumping too much oil thats making a mess. Any ideas what would be a good donor for a new rear end?
  2. Flatlander
    Flatlander
    Send a PM to Fireball350. He just put a new rearend in his 53 cusomline. I believe that it was a ford 8" out of a Mustang, cant remember the year tho. It was an inch or so narrower. Fits great, dropped his RPM a decent ammount.
  3. bulletproof1
    bulletproof1
    from tulsa okla
    maverick will fit ..
  4. I used a early mustang. Pads are in the right spot and the bolt pattern on the axel flange is the same so I just used the 53 brakes and ebrake cables rather than try to make the Mustang stuff work
  5. Squablow
    Squablow
    I have a '70 Mach 1 9" in mine, fits but it could use a little more room. I've heard that the Maverick ones are a good fit, either way you retain the correct bolt pattern. 57-59 Ford smooth back 9" rears are also a popular choice.
