1952-59 Ford 53 headlight rings???
Discussion in 'Off Topic Hot Rods & Customs' started by lincolnhead, Mar 6, 2012.
  1. lincolnhead
    lincolnhead
    from Marysville
    Ok so I know its a stupid question but I have been told that my headlight rings are pot metal and I can't weld them in to French them. However if you check my build thread I have stripped all the paint and primer and they look like steel to me. My buddy tells me don't try and buy the frenching kit. But from what I have read here that some use the 53/54 headlight rings to French.
    Can I just French my OE headlights without having to spend money and get a kit? I so much would rather use the money else where.
    Please help...
    Thanks in advance,
    Chris
  2. lincolnhead
    lincolnhead
    from Marysville
    Ok nevermind then lol.
  3. Nite Owl
    Nite Owl
    The '54 headlight rings are pot metal. '53 are steel. If they are '53 you should be able to weld them.
  4. carnut341
    carnut341
    53's are steel and they won't even fit a 54 fender because of the peak on the side on 54 fenders.
  5. acj
    acj
    I had a 51 ford afew years ago. I used fibergl*** matting on mine and its stiil there ...just my 2cents:D
  6. Custom_Crestline
    Custom_Crestline
    There are peaks on the '54 ford fender that aren't technically compatible with the '52-3 ford/merc rings, however they're custom cars.
    Night prowlers sells re-pop bezels and stainless rings. You can try and use panel bond adhesive, but they'll ghost around the seam.
  7. leadsledjim
    leadsledjim
    from Iowa
    I welded my 53 headlight rings on with no problems.
    More to frenching then just the welding. See how to at
    http://www.customcarforums.com/
    Contact me if you have any questions.
  8. Custom_Crestline
    Custom_Crestline
    You can also use velcro to keep the stainless rings in, fwiw.
  9. lincolnhead
    lincolnhead
    from Marysville
    sweet! thanks ill check that out! thanks you guys!
  10. Nite Owl
    Nite Owl
    I used '53 Mercury rings on my '54. Re-formed them with the peaks, welded, frenched. I think they look pretty good. Tried using panel adhesive on the pot metal '54 rings, just couldn't get rid of the "ghost" lines between the ring and fender.
  11. lincolnhead
    lincolnhead
    from Marysville
    Im leading my rings and fenders. thanks to my 75.00 score on oxy/acet torch set up with bottles on CL!
