1952-59 Ford 53 idler arm bracket
Discussion in 'Off Topic Hot Rods & Customs' started by westcoaster, Dec 7, 2010.
  1. westcoaster
    westcoaster
    from SoCal
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    I doubt it,I checked the Parts Manual for you, the 49-51 idler arm is night and day different in shape from a 52-53 they do however share the same part numbers for the bushings, from the illustration it appears as the 49-51 bracket is shorter than a 52-53.
  3. westcoaster
    westcoaster
    from SoCal
    do you know if the 52-53 bracket is available through and parts houses?
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    Idler arms can be had,but the bracket will probably have to come from a 52-53 donor car.
