1952-59 Ford 53' Mainline wiring
Discussion in 'Off Topic Hot Rods & Customs' started by Skaggs_32, Mar 10, 2016.
  1. Skaggs_32
    Skaggs_32
    from Texas
    Running into a few problems with wiring headlights and taillights with the rebel wiring. Does anyone know where I can find a 12 volt pigtail.
  2. JeffB2
    JeffB2
    from Phoenix,AZ
  3. Skaggs_32
    Skaggs_32
    from Texas
    Jeff, thanks for the info you are always very knowledgeable.
  4. bobss396
    bobss396
    Check out The Wiring Depot. They have wire, sockets, you name it. Helped a lot with my rewire.
  5. silverjk
    silverjk
    from Houston
    do post pics of your wiring job if you can, i plan to rewire my 53' Mainline this summer, so I would really like to see!
  6. bobss396
    bobss396
  7. Texas57
    Texas57
    Just a thought...I replaced my oem tailight sockets with sockets that had a grounding tab. That was in keeping with wiring my car as if it were a fibergl*** car. Tailights can be a particular problem because you are normally depending on sheetmetal screws to make the contact into tailight bezels which in turn may have their own contact problems due to paint, gaskets, etc. Years down the road when things rust, screws loosen, etc you start having grounding problems. Everything on my car is wired grounds to terminal strips in turn wired to a ground distribution box next to the battery.
  8. Skaggs_32
    Skaggs_32
    from Texas
    I will post pictures when I'm done, before and after.
