Projects 53 Olds 88
Discussion in 'The Hokey Ass Message Board' started by BradinNC, Mar 15, 2017.
  1. BradinNC
    BradinNC
    Just took possession of my "new" car today. Gave it a quick bath. Going up on jackstands tomorrow. My plans are to clean it up a bit and drive it. Motor is not stuck, was started every few years. 3 spd on column with 303/2 barrel carb.
  2. BradinNC
    BradinNC
  3. BradinNC
    BradinNC
  4. J. A. Miller
    J. A. Miller
    from Central NY
    Sounds like a good plan to me.
  5. VTjunk
    VTjunk
    Looks like a good one, have fun!
  6. junkyardjeff
    junkyardjeff
    It looks like a cheap model but has radio,clock,parking brake light and under dash interior lights.
    BradinNC likes this.
  7. Toqwik
    Toqwik
  8. BradinNC
    BradinNC
    You could house a small family in the trunk!
  9. Rusty O'Toole
    Rusty O'Toole
    What a great car, looks in excellent original condition. The 3 speed trans is rather rare. They were a rugged well made car, you shouldn't have much trouble putting it back in commission.
  10. belair
    belair
    Looks like a righteous reacher. Chrome bill is gonna hurt. Drivetrain is bullet-proof. Congrats.
  11. junkyardjeff
    junkyardjeff
    My first 53 Olds was a 88 2 door sedan that also had the plastic dash knobs and painted dash trim,it had a automatic trans but nothing else. No radio,clock or any other accessory lights and definately no power brakes and steering,the only option was the automatic trans.
  12. jimmy six
    jimmy six
    On the bottom alright with that stick shift... Not too many of these left, any model, but a stick even more so. Have fun...
  13. BradinNC
    BradinNC
    s55mercury66 likes this.
  14. BradinNC likes this.
  15. BradinNC
    BradinNC
    Made some progress today. Used Naval jelly on the bumpers. 2 15 minute treatments on the front, 1 treatment on the rear. Got the old Sears tires removed today. They had 95% tread remaining, slam full of cracks.
    Skankin' Rat Fink likes this.
  16. 327Eric
    327Eric
    Nice looking car.
  17. low budget
    low budget
    from Central Ky
    Good lookin ole ride! I like using SOS pads on bumpers etc. like that, then touch up with silver (chrome) paint in the areas where chrome is missing, then go back over with SOS pad and clean any access paint overspray off actual chrome and kind of blend it all together, It wont look perfect but will look better and pretty good on a budget.
  18. BradinNC
    BradinNC
    Got the engine fired up yesterday! Found a bad wire, no juice to coil, the wire from key is bad.Ran a cheater tank to byp*** the fuel tank, had 45-50 lbs oil pressure at idle. Upgraded to a newer coil, the old one was reading about 7500 ohms. The engine likes the new coil! Very pleased.
    kiwijeff, Bruce Fischer and bobwop like this.
  19. wojojo
    wojojo
    I had one of those back in the early 60s. Got it as payment for cleaning up a co-workers yard. It was a fun car.
  20. Barn Find
    Barn Find
    from Missouri
    Always loved that steering wheel center. The manual trans would be nice in an Olds.
    Hudson31 and BradinNC like this.
  21. BradinNC
    BradinNC
    IMG_20170324_110130445[1].jpg IMG_20170324_123223589[1].jpg IMG_20170324_123238376[1].jpg
    Fresh tires.
    The carb threw me off a bit. Thought it was supposed to be a Rochester but apparently these were subs***uted. Cleaning this carb up now, but if it doesn't work out, I've got a Rochester.
  22. Victory99
    Victory99
    Looks like that'll be a fun ride!
  23. carbking
    carbking
    The 2-barrel engines came with a Carter type WGD number 2015s. Your pictures do not show the tag, but carb appears original.
    The 4-barrel engines came with either Carter WCFB or Rochester 4-GC.
    The Carter WGD's are great carbs. If you keep the engine with a 2-barrel, keep the WGD.
    Jon.
    Skankin' Rat Fink and BradinNC like this.
  24. Ike Turner wrote a song about the Rocket 88.......and the rest is history.
  25. joeycarpunk
    joeycarpunk
    from MN,USA
    I had a convertible 88, the dashes were beautiful in these cars. Good luck with your project.
  26. Bradin, Glad to hear shes coming along.Bruce.
  27. BradinNC
    BradinNC
    Thanks for all the encouragement guys. Tearing down the carb now, the leather on the pump was shot. while I am doing that, I thought I'd just as well check out the tank. It needs WORK. I'll say one thing about this Olds, it's a cinch to work on compared to newer cars. I had the tank off in less than 10 minutes. Off topic car (firechicken) took 3 plus hours.
    Bruce Fischer likes this.
  28. BradinNC
    BradinNC
    Thanks for that info Jon!
    PS I just looked at your location. I am moving to your area soon. Very likely within 50 miles of you. Just waiting on my property to close in NC.
  29. That things a factory Hot Rod.
    I'm green with envy. :D
  30. tubman
    tubman
    The only good thing my old man did in his life was to buy a '53 Olds Super 88 2 door sedan new. Back in those days, it was the fastest stock car around. I was not old enough to drive, but my older brother was. I cannot tell you how many Fords, Chevy's and Mercury's we left in the dust. Neat car and do it justice.
