Projects 53 street machine build
Discussion in 'The Hokey Ass Message Board' started by nwx, Feb 8, 2011.
  1. nwx
    nwx
    from Tacoma, WA
    Front seats are in
    As with most aspects of the previous build, I rushed through the wiring and need to re-do the entire mess. Now is looks like my dash puked
  2. hotrodscott2003
    hotrodscott2003
    Just an opinion...keep the tires, loose the wheels! Car looks great, can't wait to see it in person...by the way, the previous owner loves the direction this is going!
  3. nwx
    nwx
    from Tacoma, WA
    yeah, the rims are on the short list. thanks for the thumbs up Scott.
  4. nwx
    nwx
    from Tacoma, WA
    I was able to get the exhaust cutouts and mufflers hung today.
  5. GaryB
    GaryB
    from Reno,nv
    cool build,like where it's going.what do you have in mind for the engine?
  6. nwx
    nwx
    from Tacoma, WA
    Right now the engine is a pretty stock 350, 9.5:1 compression, the "Mutha Thumpr" cam, noisy straight cut gear drive, single 4barrel tunnel ram with a holley 750 etc. It should sound and look cool, get some burn outs accomplished (especially with the 4 speed) but I wont be bragging about any real horsepower. The plan is to build a better motor this winter.
  7. nwx
    nwx
    from Tacoma, WA
    Slow but sure, todays goal is done. I was able to set the new steering column and relocate the clutch/brake pedal and place the throttle. The original pedals came through right about where the steering is now. I was able to use the old felt insulation around the clutch and brake as well.
    I had to fiddle with the sheet metal around the throttle to get it in the perfect spot
  8. Piston Farmer
    Piston Farmer
    u must have small feet, those pedals look really close togthere, so whats the paint plan for the car?
  9. Francisco Plumbero
    Francisco Plumbero
    from il.
    I see a problem with the ladder bars.
    As a reference I am using the fitment per Chris Alston's drag race ch***is tuning manual.
    The ladder bars are supposed to be focused towards a point of reference at the front of the frame, I think it is the center line of the height of the front suspension. I am not exactly sure of that, but I do know that this angle is critical and calculated to achieve maximum launch and balance and stability under load, it is not a random angle. We shouldn't just be looking at it and guessing it's good, it gets a dial protractor and some degreeing in.
    You may want to question a few builders on here or seek some more info about this and possibly a few other ch***is geometry related things. See if you can consult some ch***is guys. El Polacko or HRCC, and there are many others.
    It would **** for you to launch to the wall.
  10. nwx
    nwx
    from Tacoma, WA
    The brake pedal pad is going directly over the arm, the clutch pedal pad will be extended over to the drivers side a bit.
    For this summer, the paint stays. I want to drive the thing a bit. Next winter I am hopeful to get the paint done and a real motor built.
  11. nwx
    nwx
    from Tacoma, WA
    Thanks for the post Fransisco! I did research instant center and other aspects of suspension geometry. I have not gone through the process of finding the cars center of gravity (apparently it has to be done when the car is complete, even full of fuel and fluids). At the end of all that research, I just guessed at the ladder bar length. It seems that ladder bar designs are varied quite a bit, hell, Jegs has a bolt on deal! I wanted this to be an "old tech" build so I stuck with the leaf springs rather than going a full 4 link and coilovers. I did send a PM to ElPolako to get another opinion.
  12. 64LeSabre455
    64LeSabre455
    from Adkins, Tx
    I have seen it and yes there is!
    Didn't know you had a build thread on this. Subscribed!!
    Let me know when you need to pull the body again!
  13. nwx
    nwx
    from Tacoma, WA
    Thanks Kimb82!
  14. nwx
    nwx
    from Tacoma, WA
    Alright, body back off the frame, engine on stand ready to get pretty. I have some metal work left, then sand blast, then paint.
  15. nwx
    nwx
    from Tacoma, WA
    I dropped the oil pan and found one of the con rods just a little loose. The bearings are not worn through to the copper, the crank still looks perfect. I will sneak some new bearings in, plasti gauge, and call it good.
  16. nwx
    nwx
    from Tacoma, WA
    New bearings installed
    Looks a bit better now..
  17. 64LeSabre455
    64LeSabre455
    from Adkins, Tx
    Nice work!
    Good thing you looked at the motor a little better, that would have ****ed to have your first ride be so short!
  18. nwx
    nwx
    from Tacoma, WA
    I like this part...
    Another shot
    I even had my wife out wrenchin today!
  19. hotrodscott2003
    hotrodscott2003
    Did you give up? What's the latest? HHHHEEELLLLOOOO!!!
  20. 64LeSabre455
    64LeSabre455
    from Adkins, Tx
    Need a status update!!!
  21. HotRod60F100
    HotRod60F100
    Yeah def.! I wanna see this baby finished.
  22. nwx
    nwx
    from Tacoma, WA
    After a great summer of doing other stuff.. I am back to work on this one..
    Fuel tank installed
    Firewall painted
    I also have the underside of the body cleaned up and should be ready to set back on the frame soon
