54 Caddy Intake/Carb adapter plate available?
Discussion in 'The Hokey Ass Message Board' started by RickRenn, Oct 13, 2006.
  1. RickRenn
    RickRenn
    Anybody know if theres an intake adapter plate made for a 54/55 cadillac 331cu to fit a newer holley carb?
    Thanks Rick
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Sure, I see them all over the place at swap meets. You can usually pick one up for $5.
  3. yorgatron
    yorgatron
    why not rebuild the Rochester 4G? :confused:
  4. RickRenn
    RickRenn
    I have a couple of fresh holley rebuilds sitting on a shelf...
    Rick
  5. trippleOGalex
    trippleOGalex
    im looking for one of these adapters too. any help please
  6. carbking
    carbking
    As a point of interest, you might try a simple test.
    Put the worn-out Rochester on and run three 0-60 runs and get an average. Now run through a tank of fuel to see how far you go. Write down the results.
    After installing the adapter and the Holley, repeat both the 0-60 and the tank of fuel runs; and compare your results to the worn-out Rochester. You just might be in for a surprise!
    Jon.
  7. 73RR
    73RR
    Watch ebay for 4-hole adapter plates. Nothing there today but I have bought many for about $15.
    The biggest concern is to not have a giant bore mismatch. If your manifold is off the engine you might have the throttle bore walls sonic checked to see if there is an opportunity to bore them out a bit to try and match the Holley pattern.
  8. M.Edell
    M.Edell
    A Holley looks out of place on a Caddy...
  9. trippleOGalex
    trippleOGalex
    well i recently bought this 54 coupe....it runs with the stock carter carb. i just thought maybe when i rebuild the engine maybe a 4bbl holley can make it perform better. but then i notice the holley is wider then the stock one. so i thought their should be adapter somewhere out their.
