54 chevy 2 doors conversion
Discussion in 'The Hokey Ass Message Board' started by erospeed, Mar 8, 2010.
  1. erospeed
    erospeed
    hi, i have a 54 chevy 4 doors, and i want to convert to 2 doors and chop top.i need to use coupe doors or i can use the original ones and weld the rear doors?? please some ideas or photos !
  2. BEAR
    BEAR
    there are alot of video's on you tube that show you how to do that
  3. redsdad
    redsdad
    Most, not all but most, will agree that if all you do is weld up the back doors and leave the stock 4-door front doors as is, they will look wrong because they are too short.
    Finding 2-door doors would probably be the easiest from an amount of work point of view. Lengthening the 4-door doors would probably be easier from an availability point of view. I mean if you find a 2-door with good doors on it as a donor car, it will probably be in good enough condition to use the whole car as the starting point of your project instead of continuing on with the 4-door car.
  4. skyrodder
    skyrodder
  5. erospeed
    erospeed
    any 54 photos? to take ideas
