54 Chevy 210 SBC
Discussion in 'The Hokey Ass Message Board' started by Redtoptravis, Mar 26, 2013.
  1. Redtoptravis
    Redtoptravis
    Can i use the orriginal radiator with a small block chevy? Im guessing i need to do electric fan because a machanical doesnt fit.
  2. yetiskustoms
    yetiskustoms
    Just put in a alum champion rad off of Ebay if your Trying to save some money. I ran them on two different cars and currently my daily. Cheap and work great.
  3. a little tinkering on core support and 55 chev v8 rad fits good
  4. Redtoptravis
    Redtoptravis
    Has anyone had luck running the orriginal rad?
  5. 54rat210
    54rat210
    Yer gonna need to upgrade the radiator. Theres a thread around here about it...I think.
  6. black 62
    black 62
    from arkansas
    if it is a good radiator it will work---been done many times ...
  7. Redtoptravis
    Redtoptravis
  8. alex1954chevy
    alex1954chevy
    I used the original radiator with a hopped up sbc when i first did my swap. i never had an issue. i eventually installed an aluminum radiator just because i wanted a nicer looking engine compartment.
  9. Redtoptravis
    Redtoptravis
    Thanks Everyone!
  10. 56sedandelivery
    56sedandelivery
    Short water pump, and you should't have to move the radiator. The only concern would be corrosion/deposits in the stock radiator, so you might want to have it gone through. BUT, at the price to do that, you can get an off-shore radiator like already mentioned. Butch/56sedandelivery.
  11. davidbistolas
    davidbistolas
    Why doesn't the mechanical fan fit? Mine fit in my '51 with LOTS of spare room.
  12. gimpyshotrods
    gimpyshotrods
    If you mount the engine as far back as it will go, with the "ribs" removed from the firewall, and use a short water pump, you can use a mechanical fan.
  13. Boones
    Boones
    from Kent, Wa
    1. Northwest HAMBers
    I ran a new radiator for a 6cyl all last summer with no issues. Now it is not very hot here in the NW but never had an issue. My sbc is basically stock with mechanical fan. I am not sure it would handle a hopped up motor. I do plan to upgrade to a 4 core in the future.
  14. Redtoptravis
    Redtoptravis
    My engine came from a suburban so I guess its not a short water pump. I'll look into it. Thanks
  15. jimstro16
    jimstro16
    Short water pumps are cheap and plentiful. I plan to use a short pump and a solid fixed fan in my '50. To fit the sbc I had to cut the ribs, just the lower parts to push engine to rear and it clears the radiator and bracket perfect.
    As for cooling with the sbc the stock rad, no advise for you yet.
