54 Chevy Alternator Bracket
Discussion in 'The Hokey Ass Message Board' started by flchingon, Jul 5, 2011.
  1. flchingon
    flchingon
    What type of alternator bracket are you all using when doing a conversion on a 1954 235 and where are you getting them? Also whats the best 1 wire alternator to get? Im not gonna have a radio or electric fan...Thanks in advance..
  2. rougebeats
    rougebeats
    My best advice is to drill/slot out your existing 6 volt generator bracket so you can move it forward enough to match the alignment of the new 12V alternator pulley with all the other pulleys. Use a long bolt on the bottom with some lock washers and it wont budge. Its how I have mine and it is rugged and solid with no wear on belts or wabble at any rpm. Just have to align the pulleys correctly.
  3. knotheads
    knotheads
    i used a 65 chevelle alt bracket on my kids change over.
  4. rougebeats
    rougebeats
    I want to say my 1 wire was from a 1977 Camaro. When you wire it, you will need to wire the no. 2 terminal to the Batt. post- This is what will "excite" your alternator to begin charging since you will be removing the voltage regulator. Takes mine approx 1200-1500 rpm to engage.
  5. SlickRick83
    SlickRick83
    from merced
    i bought a cheap universal chrome alternator bracket from pep boys. it works just fine.
  6. d2_willys
    d2_willys
    from Kansas
    Mid '60s Chevy alternator bracket, then redrill accordingly.
  7. Gabriel Howard
    Gabriel Howard
    from OKC
    1. Okie Hambers
    i used the generator bracket, just flipped it and then some washers to align the belts, got the 1 wire alt from autozone
  8. Hot Rod Chris
    Hot Rod Chris
    DL7140m is our auto zone part number for the gm 1wire
  9. flchingon
    flchingon
    Cool thanks for the help and part number..Looks like Ill just be getting a universal mount...Kinda find it hard to pay $70 for the one that is offered for the car..
